Electrostatic Forces and Coulombs Law Question
Two positively charged spheres with a combined charge of 5.4 x 10^-5 C experience a repulsive electrostatic force of 1.04 N when separated by 2.2 m. The discussion revolves around applying Coulomb's law to determine the charge of the smaller sphere. Initial calculations led to an incorrect interpretation of the electric field, prompting a reevaluation using the relationship between the charges. Participants suggest rearranging the quadratic equation derived from Coulomb's law for accurate solutions. The conversation emphasizes the importance of correctly applying the equations to find the individual charges.
KMjuniormint5
Two small, positively charged spheres have a combined charge of 5.4 x 10-5 C. If each sphere is repelled from the other by an electrostatic force of 1.04 N when the spheres are 2.2 m apart, what is the charge on sphere with the smaller charge?
Coulombs equation = k(q1)(q2)/(r^2)=E
Force=(q)(E)
Plugging in what I knew I got E=1.00301x10^-5, took that and plugged it in the force equation . . .1.04=q(1.00301x10^-5) and found q to be 1.03687x10^-5 since Q+q=5.4 x 10-5 and we know now q . . .I just found Q to be 4.36313x10^-5 . . .so doesn't that make 1.03687x10^-5 the answer?
The equation you have for E is actually force. I don't understand how you could calculate E anyway since you don't know what the charges are. You just have to use the fact that you know the sum of the charges and rewrite it to get an equation for one charge in terms of the other. Sub that into the force equation and solve.
ok I have done that as well where x+y=5.4 x 10-5 solved for say y and and plugged in:
1.04=[(k*x*((5.4 x 10-5)-x))]/(2.2^2) and I ended up with the quad. eq:
0=(-5.5991x10^-10)+(5.4x10^-5)x-x^2 . . then I used the quad equation to solve for x to be -8.9901x10^-5 or -1.8099x10^-5 . . .am I on the right track?
Yes you're on the right lines, but try and rearrange the quadratic so that the q^2 term has no constants in front of it and apply the quadratic formula.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
