Finding the electric field for a point above the center of a square loop
The problem involves finding the electric field at a distance z above the center of a square loop that carries a uniform line charge Q. The discussion revolves around the application of integral calculus to determine the contributions of the electric field from the loop's sides.
  • Participants discuss splitting the integral into four line integrals corresponding to each side of the square loop. There is a focus on integrating the vertical components of the electric field while noting that horizontal components cancel out. Questions are raised about the correctness of the integral expressions and the process of integration itself.
Some participants provide expressions for the electric field and confirm the approach of integrating over the sides of the square. Others suggest referencing previous examples from Griffiths to aid in understanding the substitutions needed for the variables involved. There is an ongoing exploration of the implications of symmetry in the problem.
Participants mention the need to clarify the coordinate system and the assumptions regarding the uniformity of the charge distribution. There is also a reference to the complexity of notation in electromagnetism as a potential barrier to understanding.
JasonJo
Find the electric field a distance z above the center of a square loop carrying a uniform line charge Q.
So we want the electric field generated by the charges that lie on the boundary of the "square loop" - it's just a square or a rhombus with equal lengths.
I attempted to solve this by splitting up the integral into 4 line integrals (each side of the square loop being an integral). Since the charge is uniform, I pull that out of the integral.
Furthermore, all the horizontal components of the electric fields cancels out so we need to integrate the vertical components, i.e. [tex]cos(\theta) = \frac{z}{\sqrt( (x-x_{0})^{2} + (y-y_{0})^{2} + z^{2})}[/tex]
Am I correct to assume that one of my integrals will look like this:
[tex]\frac{Qz}{4\pi\epsilon_{0}}\int_{0}^{a}\frac{dx}{((x-x_{0})^{2} +(y-y_{0})^{2} + z^{2})^{3/2}}[/tex]
Since [tex]R^{2} = (x-x_{0})^{2} + (y-y_{0})^{2} + z^{2}[/tex], i.e. assume the points on the square's boundary are (x, y, 0) and the point above the center of the square loop as coordinates [tex](x_{0}, y_{0}, z)[\tex]<br /> <br /> z is a fixed number!<br /> <br /> My questions are:<br /> 1) Would this be a correct expression for one of the line integrals?<br /> 2) How exactly do I integrate such an expression? Am I not seeing the antiderivative?<br /> <br /> Sorry if I'm not being clear or concise, this is my first attempt at learning electromagnetism (I'm learning out of Griffiths and I am having a little trouble with all the notation and what not).[/tex]
I assume we are talking about problem 2.4 in Griffiths?
We put the origon of our coordinate-system in the center of the square. Now we look at one of the sides - we can choose the right one, whose parameter is:
r'(t) = (a/2 ; t ; 0)
where t runs from -a/2 to a/2.
Our vector r (the one going from the origin to our field point) is just (0 ; 0 ; z). So we put this in the expression for the electric field:
[tex] E = \frac{\lambda }{{4\pi \varepsilon _0 }}\int_{ - \frac{a}{2}}^{\frac{a}{2}} {\frac{z}{{\left( {\left( {\frac{a}{2}} \right)^2 + t^2 + z^2 } \right)^{\frac{3}{2}} }}} \,dt[/tex]
This is the contribution in the z-direction, since all the other components cancel out. The other 3 sides give the same contribution, so just multiply the result by 4, and then you're set.
EDIT: Actually, I see this is what you have already done.. perhaps I should start reading threads before commenting them.
[tex]E = \frac{\lambda }{{4\pi \varepsilon _0 }}\int_{ - \frac{a}{2}}^{\frac{a}{2}} {\frac{z}{{\left( {\left( {\frac{a}{2}} \right)^2 + t^2 + z^2 } \right)^{\frac{3}{2}} }}} \,dt[/tex]
Looks right. But it only looks like that because of symmetri so that E only has a komponent in the z direction. Now just substitute the constants together and it looks completely like ex 2.1 in griffith :)
Hi.
Regarding this question, my friend said all you have to do is use Example 2.1 and substitute L for a/2 and z for [tex]\sqrt{z^{2} + (\frac {a} {2})^{2}}[/tex]
This gives the right answer... I understand the substitution for L however the substitution for z I can't get. Anyone care to shed some light?
I believe that they want you to look at the previous example with the wire. If we are to chop the square loop into infinitely thin wires, then there would be pairs of wires with opposing electric fields, except for the wire directly under the charge. Therefore you simply refer to the problem before and subsititue a/2 (square loop has side a, they integrated from 0 to L and doubled the answer) for L.
10K
  • · Replies 17 ·
