A programme to change name of a file in linux
The discussion revolves around creating a program to rename files in a Linux directory, specifically targeting files transferred from a Windows environment that contain spaces and special characters. Participants explore various methods, primarily using shell scripting, to achieve this renaming task.
  • Homework-related
  • Leon seeks advice on how to write a program in C to rename files by replacing spaces and special characters with underscores.
  • One participant suggests a bash script using a loop to rename files, demonstrating the use of the `mv` command and `tr` for character replacement.
  • Another participant advises against using C for this task, suggesting that a bash script is more appropriate and less complex.
  • Leon expresses difficulty in executing the provided bash script and asks for clarification on how to run it.
  • A participant explains how to run a bash script, mentioning the need to make it executable and providing alternative methods to execute commands directly in the shell.
  • Leon reports errors encountered while running the script, indicating issues with file paths and naming conventions.
Participants generally agree that using a bash script is more suitable than writing a C program for renaming files. However, there is no consensus on the specific implementation details or the resolution of errors encountered by Leon.
Some participants note the potential for errors in the script related to file naming conventions and the handling of special characters, but these issues remain unresolved.
leon1127
Hello. I am writing a programme that changes the names of files in the linux directory. More specifically I have transferred a lot of files from windows directory which contains a lot of spaces and special characters that can get annoying in linux, so I am trying to write a programme to replace all the spaces and special character into _.
I tried to look up reference in C but most of them just talking about now to do that in the content of files but not the name of the file. Does anyone have an idea how to do it?
I will appreciate any comment.
Leon
Technology news on Phys.org
In bash,
for f in *; do
mv \"$f\" `echo \"$f\" | tr [:space:] _`
done
Since I'm paranoid I would make the line "echo mv \"$f\" `echo \"$f\" | tr [:space:] _` "
and capture the output of the command to a file with >> doit.sh
Then you can check the commands in the file before doing "source doit.sh" to run them.
i am a little bit weak in shell... what is the command that uses this shell script?
You don't want make a C program to just rename files. That's overkill. Save the code mgb_phys gave you into a file and run it with the bash command.
mgb_phys said:
In bash,
for f in *; do
done
It didnt work... i put
$ sh doit.sh
is it rite?
You can either type the commands at the prompt (tricky)
Or if you put a series of commands in a file you can either run it with sh by doing "bash blah.sh" or put "#! /bin/bash" as the first line, make it executable with "chmod +x blah.sh" then just do "blah.sh"
Bash might be the default shell on your system, in which case you can just do sh.
In addition to all this, you can also make the command just echo the comand it would have run and capture those lists of commands to a file, you can then run that file by doing "source doit.sh". The names of the files and extentions don't matter, it's just a convention to call them .sh and to call use once throwaway files "doit"
i run it and got error like
mv: target `"Hull_J._Options,_futures,_and_other_derivative_securities_(2ed.,_PH,_1993)(K)(T)(505s)_MVspf_.djvu"_' is not a directory
mv "Hull J. Options, futures, and other derivative securities (2ed., PH, 1993)(K)(T)(505s)_MVspf_.djvu" "Hull_J._Options,_futures,_and_other_derivative_securities_(2ed.,_PH,_1993)(K)(T)(505s)_MVspf_.djvu"_
mv: cannot stat `"Interest_Rate_Models_an_Infinite_Dimensional_Stochastic_Analysis_Perspective.pdf"': No such file or directory
mv "Interest_Rate_Models_an_Infinite_Dimensional_Stochastic_Analysis_Perspective.pdf" "Interest_Rate_Models_an_Infinite_Dimensional_Stochastic_Analysis_Perspective.pdf"_
mv: target `"J.London_-_Modeling_Derivatives_in_C++.pdf"_' is not a directory
mv "J.London - Modeling Derivatives in C++.pdf" "J.London_-_Modeling_Derivatives_in_C++.pdf"_
mv: target `"JORION_FRM_Handbook_3rd_ed..pdf"_' is not a directory
mv "JORION FRM Handbook 3rd ed..pdf" "JORION_FRM_Handbook_3rd_ed..pdf"_
mv: cannot stat `"John.Wiley.and.Sons.Financial.Instrument.Pricing.Using.C.Plus.Plus.eBook-LiB.chm"': No such file or directory
mv "John.Wiley.and.Sons.Financial.Instrument.Pricing.Using.C.Plus.Plus.eBook-LiB.chm" "John.Wiley.and.Sons.Financial.Instrument.Pricing.Using.C.Plus.Plus.eBook-LiB.chm"_
mv: target `"Luenberger_D.G._Investment_science_(Oxford,_1998)(T)(510s).djvu"_' is not a directory
mv "Luenberger D.G. Investment science (Oxford, 1998)(T)(510s).djvu" "Luenbergerand idea?
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 16 ·
