What is Mach's Principle and its significance in modern physics?
  • Context: Graduate
  • Thread starter Thread starter einstein_vishnu
    Principle
The discussion revolves around Mach's Principle, its implications in modern physics, and its relationship with Einstein's theory of general relativity. Participants explore the historical context, interpretations, and ongoing debates regarding the principle's significance and validity within the framework of contemporary physics.
  • Historical
  • Some participants seek clarification on Mach's Principle and its foundational basis, questioning its inclusion in Einstein's theory of general relativity.
  • Others provide references to literature, including works by Dr. Mendel Sachs and Ernst Mach, discussing the evolution of Einstein's interpretation of Mach's Principle over time.
  • It is noted that while Einstein initially aimed to integrate Mach's Principle into general relativity, there remains considerable disagreement about the extent to which this integration is successful or meaningful.
  • One participant mentions that Mach's conjecture is still an open problem and that many physicists do not consider it crucial for general relativity, citing solutions found by DeSitter that do not require matter.
  • Another viewpoint suggests that if Mach's Principle were accepted, it would necessitate treating centrifugal forces as real, contrasting with mainstream interpretations that regard them as imaginary.
  • A participant proposes that if the number of Higgs particles in the universe is finite, removing a galaxy would affect the mass of remaining atoms, raising questions about the implications of Mach's Principle on mass and inertia.
  • Some participants reference historical perspectives, including Bishop Berkeley's writings, as potentially relevant to the discussion of Mach's Principle and its philosophical implications.
  • There are mentions of Julian Barbour's works, which propose a deeper connection between general relativity and Mach's Principle, although one participant expresses skepticism about the correctness of Mach's Principle itself.
Participants express a range of views on Mach's Principle, with no consensus reached. Some acknowledge its historical significance and ongoing relevance, while others question its validity and applicability within modern physics.
Discussions highlight the ambiguity surrounding the definitions and interpretations of Mach's Principle, as well as the challenges in understanding the physical mechanisms that might support it. The conversation reflects a mix of historical context and contemporary interpretations, with unresolved mathematical and conceptual issues.
einstein_vishnu
please,any one could help in in illustrating the mach's principle.I want to know on what basis he has arrived at the conclusion.some best articles that u suggest to gothrough...
does einstein's theory include the principle or not?i think it has got the place in gr.
Einstein vs. Bohr by Dr. Mendel Sachs
The Science of Mechanics by Ernst Mach
http://www.padrak.com/ine/INERTIA.html
http://www.compukol.com/mendel/articles/The_Mach_Principle.pdf
http://www.encyclopedia.com/html/M/Machspri.asp
2.4 "Mach's Principle"
To be sure, for a number of years Einstein expressed the ambition of the general theory of relativity to fully implement Mach's program for the relativization of all inertial effects, even appending the so-called "cosmological constant" to his field equations (1917b) for this purpose. This real point of contact of Mach's influence was clearly identified only in 1918, when Einstein distinguished what he baptized as "Mach's Principle" (roughly, that inertial effects stem from an interaction of bodies) from the principle of general relativity which he now interpreted as the principle of general covariance. Taken together with the principle of the equivalence, Einstein asserted that the three principles, were three "points of view" on which his theory rested, even if they could not be thought completely independent of one another. Despite Einstein's intent, there is considerable disagreement about the extent to which, if at all, general relativity conforms to "Mach's Principle". In part this is due to vagaries regarding what the Principle actually asserts and then again, to difficulties in comprehending what physical mechanism might implement the Principle, however interpreted. How, for instance, could a body's inertial mass be accounted due to the influence of all other bodies in the universe? (See the discussions in Barbour and Pfister (1995)).
SOURCE: http//plato.stanford.edu/entries/genrel-early/URCE:
http://scienceworld.wolfram.com/physics/MachsPrinciple.html
Mach's conjecture is still an open problem,it was not disproved yet.However,in spite of Einstein's intentions,nowadays physicists do not consider it (Mach's principle) as crucial for General Relativity;indeed DeSitter found solutions of Einstein's equations characterising expanding universes even in the total absence of matter.Thus it is accepted the minimum interpretation,the principle of equivalence could represent only a partial integration of Mach's principle into GR.This interpretation is evident even in the usual approaches of classical problems,for example if we were to accept Mach's principle (as Mach put it) then we should treat centrifugal forces as being real forces or in all mainstream treatises it is specifically underlined the fact that they are imaginary.
Mach thought that the inertia of a local mass was caused by all the other masses
in the universe.If there are a finite number of Higgs particles in the universe to cause mass, isn't this true? If I could remove a galaxy from the universe then the higgs particles associated with its atoms would be redistributed among the remaining atoms of the universe and they would presumably all have a slightly higher mass than before.
I recall reading Einstein said that Mach's principle in its' original form had been very helpfull in early days of GR development.During the years he admited he changed his mind about interpretation of the principle (ie the meaning of it).
Still open problem,I agree.
The principle was to address the problem of centrifugal force, which had managed to preserve some vestige of the notion of absolute space which remains inescapable in most classical mechanical treatements that are not specifically taylored to eliminate it.
You can look into some of the writings of Bishop Berkeley for a related perspective.
You can find a treatement of Mach's principle in the translated work of Einstein, The Meaning of Relativity. The weak, low velocity approximation is used. A material particle is indirectly demonstrated to experience a centrifugal and coriolis force by virtue of the motion of the source body.
turin,
Would you be kind and be more specific regarding Bishop Berkeley's writings you are referring to?I didn't read it.Publisher,title?
TeV
This is going to sound terribly uncongenial, but no. I remember reading some stuff in passing, but I didn't write it down, and I don't have time to go track it down. I did a quick search on the web just before I posted that last post of mine in order to see if I could pin down a specific citation or source, but to no avail. You can consider the name as a tenuous lead, and follow it if you are truly interested.
Just so we're clear and you don't get surprised though, Mr. Berkeley was a straight-up philosopher, not a physicist. It wasn't so much what he said; it was the clarity with which he exposed a long-time concern of mine that I could never seem capable of communicating. Frankly, he may be quite bogus, but I happen to agree with the little that I have read.
Consider going to Amazon and doing a search on Julian Barbour. I have a copy of his _Mach's Principle: From Newton's Bucket to Quantum Gravity (Einstein Studies, Vol 6)_
which is out of print but might be availalbe at university libraries, and have pre-ordered _Absolute or Relative Motion: The Deep Structure of General Relativity_ which he has been promising for years now... He alludes to some of the ideas he will present in his _The End of Time: The Next Revolution in Physics_ and claims a deep connection between GR and Mach's principle beyond what even Einstein held, then backed away from.
(I on the other hand do not think Mach's principle is correct, and inertia can be explained as a local phenomina related to mass. But this is purely a personal view, and a side issue of my own research.)
  • · Replies 28 ·
  • · Replies 32 ·
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 67 ·
12K
