Calculating Energy Change in Compton Scattering
The discussion revolves around a physics problem involving energy change during a collision, specifically relating to Compton scattering. The scenario describes an object with known mass and velocity colliding with another stationary object of the same mass, and the goal is to determine the energy change based on the scattering angle and the target object's velocity after the collision.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the energy and momentum conservation equations relevant to the collision, questioning the assumptions made about the nature of the collision (elastic vs inelastic). There is also a focus on the implications of the scattering angle on energy loss.
The discussion is active, with participants providing feedback on the original poster's approach and pointing out potential errors in the calculations. Some participants suggest reconsidering the assumptions about the collision type and the implications of the scattering angle on energy loss.
There is mention of the collision occurring in two dimensions and a note that the angle of the target object can be algebraically removed. Participants also highlight a missing factor in the calculations that could affect the final result.
ajhunte
Can Someone look over this and tell me if the work is correct.
An object comes in with known velocity (v) and known mass (m) moving directly along the x-axis. It strikes another object of the same mass (m) which is stationary. Find the change in energy of the incoming object based on the angle at which it scattered ([tex]\theta[/tex]) and the velocity of the target after the collision (u). The collision only occurs in 2 dimensions. (Note: The angle at which the target object is moving can be removed algebraically.)
[tex]E_{i}[/tex]=Energy of Incoming Object before collision
[tex]E_{f}[/tex]=Energy of Incoming Object after collision
[tex]E_{2}[/tex]=Energy of Target Object after collision
[tex]p_{i}[/tex]= Momentum of incoming object before collision.
[tex]p_{f}[/tex]=Momentum of Incoming object after collision.
[tex]p_{2}[/tex]=Momentum of Target object after collion.
[tex]\phi[/tex]= Arbitrary Angle of Target object scattering (should not matter based on the note.
[tex]E=1/2*m*v^{2}[/tex]
p=m*v
[tex]p^{2}/(2*m)=E[/tex]
Energy Balance:
[tex]E_{i}=E_{f}+E_{2}[/tex]
X-Momentum Balance:
[tex]p_{i}=p_{f}*Cos(\theta) +p_{2}*Cos(\phi)[/tex]
Y-Momentum Balance: (This should be a zero momentum system in y-direction)
[tex]p_{f}*Sin(\theta)=p_{2}*Sin(\phi)[/tex]
Squaring only the Momentum Equations and adding them together.
Y-Balance:
[tex]p_{f}^{2}*Sin^{2}(\theta)=p_{2}^{2}*Sin^{2}(\phi)[/tex]
X-Balance: (after getting [tex]\phi[/tex] isolated on one side then squaring)
[tex]p_{2}^{2}*Cos^{2}(\phi)=p_{i}^{2} - p_{i}*p_{f}*Cos(\theta)+p_{f}^{2}*Cos^{2}(\theta)[/tex]
Adding the two momentum Equations and using [tex]Sin^{2}+Cos^{2}=1[/tex]
[tex]p_{2}^{2}=p_{i}^{2}-p_{i}*p_{f}*Cos(\theta)+p_{f}^{2}[/tex]
Relating back to energy, using the relationship defined in section 2.
Since all masses are the same I divide the newly found momentum equation by 2m in order to get to energy:
[tex]E_{2}=E_{i}+E_{f}-\sqrt{E_{i}}*\sqrt{E_{f}}*Cos(\theta)[/tex]
(Note: [tex]\sqrt{2m}*\sqrt{2m}=2m[/tex] and [tex]p/\sqrt{2m}=\sqrt{E}[/tex] )
Combining with the original Energy Balance Equation to Eliminate [tex]E_{2}[/tex]. This involves subtracting the equation I just solved for and the original equation.
[tex]0=2*E_{f}-\sqrt{E_{i}}*\sqrt{E_{f}}*Cos(\theta)[/tex]
Applying the Quadratic Equation
[tex]\sqrt{E_{f}}=\sqrt{E_{i}}*Cos(\theta) +\- \frac{\sqrt{\sqrt{E_{i}}^{2}*Cos^{2}(\theta)-0}}{4}[/tex]
Minus Sign Answer Leads to 0, so nontrivial answer is:
[tex]E_{f}=\frac{E_{i}*Cos^{2}(\theta)}{4}[/tex]
Is this the correct solution, or is there a step that I made a mistake or false assumption? It seems to me that this is wrong, because even a grazing trajectory decreases the initial energy by 3/4.
This is essentially compton scattering. Why do you have to angles? Also, are you assuming it is inelastic, or were you told that it is inelastic? I would probably assume an elastic collision.
Your right, this is basically compton scattering without the relativisitic effects. That is why the first 4 steps are the same as the Compton Scattering derivation. The difference is that the since this does not use relativistic effects:
[tex]E=\frac{p^{2}}{2m}[/tex]
For Compton Scattering, the conversion between energy and momentum for Photons and relativistic electron is different:
For Relativistic Electrons: [tex]pc=\sqrt{E_{0}^{2}-m_{0}^{2}c^{4}}[/tex]
For Photons: [tex]\frac{E}{c}[/tex]
This is where the difference is. That is why I asked the question, because this answer does not seem intuitive that if I have a grazing trajectory (i.e. [tex]\theta[/tex] goes to 0) I still lose 3/4 of the energy.
Hi ajhunte,
p=m*v
Energy Balance:
X-Momentum Balance:
Y-Balance:
You are missing a factor of two here. The factor of two will keep the four from appearing in the denominator of the final answer.
Thank You, That is exactly what I was missing.
