How Can I Make Lemon Myrtle Scent Last Longer in My Home?
  • Thread starter Thread starter kateman
    Life
The discussion revolves around methods to enhance and prolong the scent of lemon myrtle in a home setting. Participants explore various techniques for extracting and utilizing the fragrance, including candle making, incense production, and oil extraction methods. The conversation includes both theoretical approaches and practical considerations.
  • Experimental/applied
  • One participant suggests drying lemon myrtle leaves to create incense or candles, while others caution that drying may reduce the volatile oils responsible for the scent.
  • Another participant proposes using extracted oil to make scented wax candles, referencing online guides for DIY candle making.
  • Steam distillation is mentioned as a method for extracting oils, but concerns are raised about the need for specialized equipment.
  • A participant shares a new idea of using a small candle under a ceramic plate with oil to vaporize the scent without damaging the oils.
  • There is a discussion about the potential effectiveness of using Everclear for oil extraction and the possibility of conducting steam distillation with household items.
Participants express differing views on the effectiveness of drying the leaves and the best methods for oil extraction. There is no consensus on the optimal approach, and multiple competing ideas remain throughout the discussion.
Participants note limitations regarding the availability of specialized equipment for steam distillation and the uncertainty surrounding the purity of oil extracted using vodka. The discussion also highlights the volatility of essential oils and their sensitivity to temperature changes.
Individuals interested in home fragrance solutions, DIY candle making, or natural scent extraction methods may find this discussion relevant.
kateman
of late i have discovered the beautiful smell that my lemon myrtle can give when i rub the leaves together between my hands. It got me thinking, what can i do to get this smell throughout my house?
i have thought of two ideas so far (iam open to any others): dry the leaves and turn it into an incense candle or extract the oil by soaking the leaves in vodka and freezing the liquid so that the oil goes to the top before the vodka freezes
i was thinking of burning the dry leaves but how can i reduce the rate in which it burns (please keep in mind it can't be poisonous)?
i did think of adding charcoal with it, separate it a bit but iam not sure how well that would actually work.
any advice is welcome! :)
Chemistry news on Phys.org
Since you mentioned you had thought about extracting the oil, what about just using that to create a typical scented wax candle? There are plenty of how-to guides online about making your own scented candles, you'd just be using a homemade liquid scent instead of a commercial scent.
Otherwise, making your own incense (loose or cone/stick) at home is also very doable. Here, again, you can go online and pick your preferred method from the how-to guides out there.
I wouldn't dry the leaves first. Those oils you are smelling are volatile oils...
Extract them fresh with Everclear or try steam distillation. You might even try adding the wax to the pot and heat with a sachet of the fresh leaves. If the wax melts at something under the boiling point of water you could devise a liquid-liquid extraction system directly into the wax.
thanks to both of you for replying
why not dry them (if it isn't done at a temperature to denature the oils, that is)?
any decent way that i could conduct steam distillation considering i don't have any of the normal equipment around the place (i.e. useing household utensils)?
its just the vodka idea takes a while and has no really reassurance of its purity/concentration
oh and my new idea for getting the smell throughout the house is a small candle under a ceramic plate with the oil on top - giving enough heat to vaporise yet not enough to denature it
When you dry the leaves, you are also drying out the essential oils... since they are volatile just like water is.
Steam distillation requires specialized equipment.
Essential oils are usually pretty nonpolar things. They would extract nicely into melted wax, I believe.
thanks for that - helps a lot :)
  • · Replies 19 ·
11K
15K
  • · Replies 26 ·
