Why Do Systems Have Organization?
  • Context: High School
  • Thread starter Thread starter Gear300
    Behavior Systems
The discussion revolves around the question of why systems exhibit organization, using examples from astrophysics, atomic structure, and general system dynamics. Participants explore the underlying principles that lead to stability and order in various systems, including gravitational orbits and quantum mechanics.
  • Some participants suggest that systems must have some form of stability to persist, with gravitational interactions leading to orbital motions as a common dynamic.
  • Others propose that the organization of atoms is a result of quantum mechanical interactions, with electrons described as having stable configurations rather than following classical orbits.
  • A participant argues that systems minimize action, leading to ordered structures, and discusses the probabilistic nature of electron configurations in atoms.
  • Another participant challenges the notion that electrons "sit there," emphasizing the importance of kinetic energy and energy levels in understanding atomic structure.
  • Some participants express that simplified models, like the planetary model of the atom, can aid in understanding complex concepts, despite their inaccuracies.
  • One participant raises the idea that systems may be inherently disorderly, with organized states being highlighted as exceptions.
  • Another point made is that the selection of systems for analysis often depends on the context and the properties being examined, such as symmetry and potential energy considerations.
  • A question is posed about whether organized systems are probable outcomes or if they exist due to their necessity for existence.
Participants express a range of views on the nature of organization in systems, with no clear consensus reached. Some agree on the role of stability and energy minimization, while others contest specific models and interpretations of atomic behavior.
Participants acknowledge that the discussion involves complex concepts from physics, including quantum mechanics and thermodynamics, which may not be fully resolved or universally agreed upon. The limitations of simplified models and the dependence on specific definitions are also noted.
Gear300
Why is it that systems organize? For example, the planets orbit around the sun and the stars orbit around in their respective galaxies. Another example on a smaller scale is the atom. The electrons move about in probable clouds around the nucleus (if I got this right). Why do systems do this?
Well, most "systems" you talk about must have some form of stability, otherwise they would already be gone, right ? Turns out that as a function of certain interactions, stable systems, or at least systems with a long lifetime, take on certain forms of dynamics. In gravity for instance, orbital motion is the most common form. If planets weren't orbiting, they'd drop right into the sun and we wouldn't know they have existed. Also, there are certain conservation laws, like conservation of angular momentum, which mean that once a planet is on an orbital motion, it is not going to jump around, but rather remain in that orbital motion.
Makes sense...what about on a subatomic scale? Why are atoms organized the way they are.
It's pretty similar: the stable or almost stable structures are given by the quantum mechanical description that results from the interaction between the components. BTW, quantum-mechanically, electrons don't turn around the nucleus as in a planetary system. That's a pretty rough and basically erroneous model of the atom (which nevertheless seems to be rooted in popular "knowledge"). The closest description would be that the electrons essentially "sit there".
The answer is because 'systems undergo dynamic in such a way that they minimize action (or to be more precise such that they take the path of stationary action)'. This may not seem the most illumintating answer but for example, I do molecular simulations and all a simulation is doing is following the dynamics derived from calculus of variations and yet the result is a tendency to order. For your example of an electron, if say you have a nucleus which occasionally comes in contact with an electron, it is highly probably that the nucleus will 'capture' it and once an electron is 'attached' to a given atom is requires a large amount of energy to remove it (and thus this event is less likely at terrestrial temperature). Thus it's simply a matter of probability that we would expect most atoms to have full electron shells. (Of course things are more complicated then that but that's a sort of simplistic way to look at it)
I don't agree. "Sit there" doesn't do a good job of capturing the kinetic energy or the concept of energy levels. Ordinary people without giant hulking brains need an approximation to understand things, or they would have to settle for "it works cause God says so". The orbit approximation helped me understand a lot of concepts throughout school, despite the fact that, as far as I know to date, I'm too dense to grasp QM.
In fact, even the concept of quantization itself was explained in a way that fit neatly into my brain in this framework: "you know how particles act like waves with some frequency and interfere and stuff? well so if you have a wave orbiting around a nucleus then it interferes with itself so it's a standing wave right? so then it must have discrete energy levels" and that let me get a handle on things enough that I got through some pretty tough classes. It's an approximation and I know it, but why throw out my one and only dented, rusty shovel just because it ain't a backhoe?
It may mislead me occasionally, but "everything is random and there are no rules la la la la la" is a lot worse.
Well, in the scholarly hydrogen atom, in the ground state, there's one single electron in the s-state. The s-state has its highest probability of presence ON TOP of the nucleus, and no angular momentum (no rotational motion). Ok, it does have kinetic energy (equal to minus the total energy, as the potential energy is twice the total energy):
KE = 13.6 eV
PE = -27.2 eV
Etot = -13.6 eV
My desk is a counterexample- that system tends to complete disorganization.
I wonder if you are confusing an analytical, abstracted, property of systems (periodicity, stability to perturbations, etc) with some "innate" property of objects.
Well as far my knowledge of physics (which is not super) and the question of your is understood i would like to highlight following points:
1.) System selection depends on problem concerned.For simplicity we select such system whis is organised,more properly symmetric.
2.) Every system of universe tends toward lower potential energy,when it is being lowered system tends to be organised or symmetric.
Please correct the answer if i made soethunf wrong.
So are these systems just probable outcomes or are they improbable outcomes that exist only because they allow for existence?
What sort of systems? Where do you put the boundary in what is and is not allowed to be part of a "system"? Like someone said, a desk is a system but rarely is it organised :biggrin:
I think it's the other way round, everything is inherently disorderly but we just highlight the more ordered situations.
Heh...that makes sense.
  • · Replies 21 ·
  • · Replies 21 ·
