Separating Hamiltonian functions. Helium atom.
This discussion focuses on the separation of Hamiltonian functions in the context of the helium atom as presented in McQuarrie's "Quantum Chemistry." The key point is that the Hamiltonian operator allows for the treatment of each electron's momentum independently, leading to a formulation where the eigenfunctions of Schrödinger's equation can be expressed as products of eigenfunctions from simpler, separated equations. The discussion highlights the role of differential operators and the assumptions made regarding the nucleus's stationary position and the negligible effect of inter-nucleon terms.
  • Understanding of Hamiltonian mechanics
  • Familiarity with Schrödinger's equation
  • Knowledge of differential operators and partial derivatives
  • Basic concepts of quantum chemistry, particularly regarding electron interactions
  • Study the implications of separable Hamiltonians in quantum mechanics
  • Explore the derivation and applications of Schrödinger's equation for multi-electron systems
  • Investigate the role of differential operators in quantum chemistry
  • Learn about the simplifications made in quantum models, such as the stationary nucleus approximation
Students and researchers in quantum chemistry, particularly those studying multi-electron systems and the helium atom, as well as educators teaching advanced quantum mechanics concepts.
scorpion990
I'm using McQuarrie's "Quantum Chemistry" book for a little bit of light reading. He included a proof of a theorem that states that if a Hamiltonian function is separable, then the eigenfunctions of Schrödinger's equation are the products of the eigenfunctions of the simpler "separated" equations... Anyway...
I just started studying the helium atom. Schrödinger's equation is written with two different laplacian operators, one that acts "only on the first electron", and one that acts "only on the second electron". However, the laplacian for both electrons is just a differential operator which contains a mixture of partial derivatives with respect to all three coordinates. I don't understand why you can assume that the first laplacian only acts "on the first electron". After all, a differential operator (D) acting on two functions (F and G):
D(F*G) is not F*D(G) if D contains derivatives which pertain to F.
Help?
That Hamiltonian operator is looking at each interaction separately and making a statement that all of the interactions taken together describe the system completely. Omitting the inter-nueclon terms (which have little effect on the motion of the electrons), and assuming a stationary nucleus (which we can do since the mass of the nucleus is much larger than the mass of the electrons) there are 5 terms: a laplacian term that deals with the momentum of one of the electrons relative to the nucleus, another laplacian term that deals with the momentum of the other electron relative to the nucleus, and three columb terms: one for each of the electrons interacting with the nucleus and one for the interaction between the two electrons (this one is sometimes omitted to simply the problem).
So there are two momentum terms because each of the electron's momentum is independent of the others, so you need one term that deals with each.
theUndergrad
http://www.theUndergraduateJournal.com/
  • · Replies 39 ·
  • · Replies 19 ·
