Is energy relative in electrostatics?
  • Context: Graduate
  • Thread starter Thread starter aniketp
    Anomaly
The discussion revolves around the concept of energy in electrostatics, particularly focusing on the energy associated with point charges and spherical shells. Participants explore the implications of energy calculations as the radius of a spherical shell approaches zero, leading to infinite energy scenarios and the challenges in defining energy for point charges.
  • One participant presents a formula for the total energy of a thin spherical shell, suggesting that as the radius approaches zero, the energy tends to infinity, complicating the analysis of point charge systems.
  • Another participant notes that compressing uniformly distributed charge to a point requires infinite work due to repulsive forces, drawing parallels to undergraduate electrostatic potential problems.
  • A third participant references Griffiths' work, explaining that different equations for energy can yield both positive and negative values depending on the context, and emphasizes that the infinite energy of a point charge is a known issue in electromagnetic theory.
  • One participant questions whether the energy of a point charge can simply be assumed to be zero, seeking clarification on this assumption.
  • A later reply suggests that the perspective on energy reference points can vary, indicating that defining a reference point affects the perceived energy of a point charge.
  • Another participant proposes that since the focus is on changes in energy, the choice of reference point may not significantly impact the discussion.
Participants express differing views on the implications of energy calculations for point charges and spherical shells. There is no consensus on how to define or interpret the energy of point charges, and the discussion remains unresolved regarding the assumptions made about energy reference points.
Participants highlight limitations in the definitions and assumptions surrounding energy calculations, particularly regarding the infinite energy associated with point charges and the context in which different equations apply.
aniketp
Hey everyone,
Can you justify this:
The total energy of a thin spherical shell is the sum of its "self" energy and "interaction" energy.By simple calculus for a thin spherical shell,
E(total)= Q^2/8*[tex]\pi\epsilon[/tex]*R
Here,
Q: total charge
R: radius of shell
Thus as R[tex]\rightarrow[/tex]0, i.e the shell becomes a point charge, the total energy tends to infinity.So the analysis of point charge systems becomes impossible from the energy point of view.
Mmmm... two things, perhaps.
First, as R->0, I am assuming you have some uniform spread of Q over the surface. Thus the word required to compress all that charge toward a point would grow toward infinity as you tried to compress repelling charges all together into one point. It's similar to the underdivision, undergraduate problems of electrostatic potential, introducing point charges, the work done, etc.
Second, it is often assumed (if you've studied Legendre Polynomials and the solutions to the Laplace equation) that the potential is zero at infinity... however, there are times we reverse this so that our solutions don't diverge and the potential is zero at r = 0, depending on which solutions are being used.
Hope this gives a little insight.
Griffiths discusses something rather similar in "introduction to electrodynamics":
David Griffiths said:
Equation 2.45, [itex]W = \frac{\epsilon_0}{2}\int{E^2d^3r}[/itex] implies that the energy of a stationary charge distribution is always positive. On the other hand, Equation 2.42, [itex]W=\frac{1}{2}\sum_{i=1}^{i=n}q_iV(\vec{r}_i)[/itex], from which Eq. 2.45 was derived can be positive or negative... Whch equation is correct? The answer is that both equations are correct, but they pertain to slightly different situations. Eq. 2.42 does not take inito account the work necessary to make the point charge in the first place; we started with the point charges and simply found the work required to bring them together. This is a wise policy, since Eq. 2.45 indicates that the energy of a point charge is in fact infinite. Eq. 2.45 is more complete in the sense that it tells you the total energy stored in the charge configuration, but Eq. 2.42 is more appropriate when you're dealing with point charges, because we prefer to leave out that portion of the total energy that is attributable to the fabrication of the point charges themselves. In practice, after all, the point charges (electrons say) are given to us ready-made; all we do is move them around. Since we did not put them together and cannot take them apart it is immaterial how much work the process would involve. Still, the infinite energy of a point charge is a recurring source of embarrassment for electromagnetic theory, afflicting the quantum version as well as the classical.
So is there no explanation for this? And we just "assume" that the energy of a point charge is zero?
Haha, I think you just gave a very verbose quotation to what I said earlier nicksauce :-)
Its a matter of perspective, aniketp. I suppose, if you really wanted, you could place a reference point at some... say.. 50% of the way to infinity and give yourself some energy. It all depends on where you define your references if you take the point charge by itself... or if you take the view of a collapse of a bunch of charge into a "point", then it would take an infinite amount of energy since you are attempting to push repelling forces all together at exactly into a delta peak.
So is it that bcause we are just interested in the CHANGE of energy it does not matter what our reference point is?
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 38 ·
10K
