Thread Closed
MV or 1/2MV^2
Share Thread Thread Tools
Jun27-08, 09:58 PM   #1
MV or 1/2MV^2
My experience is that because a lighter bowling ball can be thrown faster, the force that the ball has is altered. Should I use MV or 1/2MV^2?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Jun27-08, 10:07 PM   #2
Recognitions:
Homework Helper Homework Help
Neither. Force is not described by 1/2mv^2 or mv.
Jun27-08, 10:11 PM   #3
Recognitions:
Can you maybe clarify your question? Neither MV nor 1/2MV^2 represents a force in any way.
Jun27-08, 10:17 PM   #4
MV or 1/2MV^2
MV = P which is Momentum.
Ke = 1/2 mv^2 which is Kinetic Energy which can be exchanged for Potential energy.
Force is typically defined as , F=ma.
Jun27-08, 11:22 PM   #5
Quote by nicksauce View Post
Yes. In the context of trying to deliver energy to the pins, I'm thinking M and V are trade offs as far as energy is concerned. A heavier ball at slower speed or a somewhat lighter ball at higher V.
Jun27-08, 11:55 PM   #6
Quote by razored View Post
The correct definition of force is F = dp/dt.
Pete
Jun28-08, 12:04 AM   #7
Just though I would throw in the more accurate formula for momentum (or so it seems)...
p = ɣmv
ɣ = (1-v^2/c^2)^(-1/2)
Jun28-08, 12:19 AM   #8
Quote by xArcherx View Post
p = ɣmv
I'm getting the dp/dt thing from calc 1 97 years ago. thank you Pete. But I missed the thing from xArcherX. Sorry. I'm rusty as hell. Break it down, as they say, please. thanks.
Jun28-08, 02:33 AM   #9
xArcherx's perspective is essentially the same as what you've been learning, but in general form. In classical physics, we mostly deal with what we can experience, which is one of the things that makes modern physics different (it tells us we've only been seeing part of the picture, and that phenomenon start acting differently over different scales).
If you've noticed, there is a c in the equations, which is the speed of light. Compared to v (the velocity of the bowling ball), its probably much bigger, so the formula for momentum can more or less be regarded as p = mv for this situation with the bowling ball.
Jun28-08, 06:16 AM   #10
Mentor
Why would you do that? It adds a totally unnecessary complication for no good reason other than to make you look smart. (And I'm afraid adding totally unnecessary complications doesn't make one look very smart)
A bowling ball might travel at 20 mph. That means we are talking about a correction in the 15th decimal place. Not only is this totally unmeasurable, it's tiny compared to the correction to the mass of the bowling ball as it travels and picks up and drops off various bits of this and that. So not only is it an unmeasurable correction, it's not even the biggest unmeasurable correction.
Jun28-08, 07:44 AM   #11
But when looking at a trade off between speed and weight, we use MV and not 1/2MV^2?
Jun28-08, 07:47 AM   #12
Mentor
Quote by mtworkowski@o View Post
What are you actually trying to calculate? It would be a lot easier if we had a well-defined problem.
Note that the two things you have formulae for are momentum and kinetic energy, respectively.
Jun28-08, 02:36 PM   #13
Quote by cristo View Post
which is better, the 16lb ball or a 15. More detail, if I or anybody can throw a 16 lb ball at the pins and deliver a certain amount of energy(let's say thats as fast as he can comfortably throw the ball) than would a lighter ball ( assuming he can throw it a wee bit faster) deliver more energy. I don't know if its momentum, kinetic energy or if either one will work.
Jun28-08, 03:10 PM   #14
D H
Mentor
Firstly, it is both conservation of momentum and conservation of energy that dictate what happens. I good starting point is to assume perfectly elastic collisions. Together, conservation of momentum and conservation of energy tell what happens.
Secondly, your physiology rather than physics is the determining factor here. You are missing a key factor, which is throwing a ball accurately. Suppose that you can throw a 16 lb ball fast enough to get more pin action than you can get with a 15 lb ball. That does not necessarily mean you should prefer the heavier ball. If the heavier ball makes you less accurate you might want to use the lighter ball.
Jun28-08, 03:20 PM   #15
Quote by D H View Post
Thanks DH..........I did better with the 15. But this is more of an academic question I guess. Compare the energy delivery of both balls when an equal force is used in each case. Maybe that says it better. Sorry.
Jun28-08, 04:53 PM   #16
Yeah it is pretty much unnecessary at speeds that are not relativistic. Although, personally, I like to work with as close to exacts as I can. I also like to try and look smart , even if it does backfire on me (something that happens way too often)
Jun29-08, 12:41 AM   #17
to all. you know my question is perfectly clear. If you can't answer it than i'm out. you can just debate it for the next thousand years, which i'm sure you will. By The idea of using relativistic physics on a bowling bowl. Ha Ha Hal. What a joke.
Thread Closed
Thread Tools
