| Thread Closed |
Derivative of 10^x using limit definition |
Share Thread | Thread Tools |
| Jun29-08, 11:51 AM | #1 |
Obtain the first derivative of 10x by the limit definition. 2. Relevant equations f'(x)=limh->0 f(x+h)-f(x)/h 3. The attempt at a solution f'(x)=limh->0 10x+h-10x/h I also know that h=1 as x approaches 0. Now, how do I make it so that you aren't dividing by h=0. |
| Jun29-08, 11:58 AM | #2 |
10x+h= 10x10h so
[tex]\frac{10^{x+h}- 10^x}{h}= 10^x\frac{10^h- 1}{h}[/tex] Now the question is, what is [tex]\lim_{h\rightarrow 0}\frac{10^h- 1}{h}[/tex]? |
| Jun29-08, 12:40 PM | #3 |
To find
[tex]\lim_{h\rightarrow 0}\frac{10^h- 1}{h}[/tex] I can't plug h=0 in because I would be dividing by 0. Do I plug in 1 since the limit as h approaches 0 is 1? |
| Jun29-08, 12:51 PM | #4 |
Recognitions:
Derivative of 10^x using limit definition[tex] lim_{h\rightarrow 0} ~10^h = 1 + a h + \ldots [/tex] where a is some numerical value and the dots represent terms of higher powers in h. The problem is to find the value of a. Here is the trick: use that any number x may be written as [tex] e^{ \ln x} [/tex]. Then use what you know about rules for logs and then Taylor expand the exponential. |
| Jun29-08, 01:35 PM | #5 |
I don't understand what this means. What is "Taylor expanding" and the "next order correction"?
| Jun29-08, 01:57 PM | #6 |
Recognitions:
[tex] e^\epsilon = 1 + \epsilon + \frac{\epsilon^2}{2} + \ldots [/tex] ? This is a Taylor expansion. Have you ever proved using the limit definition that the derivative of e^x is e^x? Then you must have used something similar to the above. If you haven't proved the e^x case and the expansion I wrote above is not familiar to you then I will let someone else help you because I don't see at first sight any other approach. EDIT: do you know what the limit as h goes to zero of [tex] \frac{e^h -1}{h} [/tex] gives? maybe you have been told this without proving it. If you know the result of this limit and are allowed to use it, then I can show you how to finish your problem. If not, I don't see how to help, unfortunately. Best luck! |
| Jun29-08, 02:13 PM | #7 |
I've never proved e^x. Thank you for trying to help though.
| Jun29-08, 02:28 PM | #8 |
Recognitions:
[tex] lim_{h \rightarrow 0} 10^h = lim_{h \rightarrow 0} e^{\ln 10^h} = lim_{h \rightarrow 0} e^{h \ln 10} \approx 1 + h \ln 10 [/tex] where I used an identity for logs and then I used the expansion of the exponential I mentioned earlier. Form this you can get the final answer of your question. Hopefully someone else will be able to find a way to show this result in some other way but I can't think of any! Best luck |
| Jun29-08, 05:24 PM | #9 |
Mentor
| Jun29-08, 05:41 PM | #10 |
Mentor
I don't know if this will be useful, but one might try using the definition of e:
[tex] e = \lim_{N \rightarrow \infty} (1+\frac{1}{N})^N = \lim_{a \rightarrow 0} (1+a)^{1/a} [/tex] or [tex] e^A = \lim_{N \rightarrow \infty} (1+\frac{1}{N})^{NA} = \lim_{a \rightarrow 0} (1+a)^{A/a} [/tex] Also, the fact that [tex] 10^h = e^{h \ln(10)} [/tex] |
| Jun29-08, 06:54 PM | #11 |
I suspect this was given as a preliminary to the derivative of ex so the derivative of ex cannot be used. It is easy to see that the derivative of ax, for a any positive number, is a constant times ax. It is much harder to determine what that constant is! It's not too difficult to show that, for some values of a, that constant is less than 1 and, for some values of a, larger than 1. Define e to be the number such that that constant is 1. That is, define "e" by
[tex]\lim_{h\rightarrow 0}\frac{e^h- 1}{h}= 1[/tex] As Redbelly98 said, 10h= eh ln(10) so [tex]\frac{10^h- 1}{h}= \frac{e^{h ln(10)}- 1}{h}[/itex] If we multiply both numerator and denominator of that by ln(10) we get [tex]ln(10)\left(\frac{e^{h ln(10)}-1}{h ln(10)}\right)[/tex] Clearly, as h goes to 0 so does h ln(10) so if we let k= h ln(10) we have [tex]ln(10)\left(\lim_{h\rightarrow 0}\frac{e^{h ln(10)}-1}{h ln(10)}\right)= ln(10)\left(\lim_{k\rightarrow 0}\frac{e^k- 1}{k}\right)[/tex] so the limit is ln(10) and the derivative of 10x is ln(10)10x. That is NOT something I would expect a first year calculus student to find for himself! |
| Jun29-08, 07:04 PM | #12 |
Recognitions:
[tex] \lim_{h\rightarrow 0}\frac{e^h- 1}{h}= 1 [/tex] is often demonstrated or proven (if it is not simply stated without proof) in the first-semester course, shortly after having covered limits and while developing the rules of differentiation. I hardly expected that the OP would have seen Taylor series yet... I believe the proof given in textbooks usually revolves around the limit definition of e, which Redbelly98 gives in post #10. |
| Jun29-08, 07:12 PM | #13 |
Recognitions:
| Jun29-08, 09:16 PM | #14 |
Recognitions:
I suspect that OP's textbook presents the limit
[tex] \lim_{h\rightarrow 0}\frac{e^h- 1}{h}= 1 [/tex] somewhere in the chapter and that a student is just asked to recognize that they could apply it, in something like the manner Halls suggests in post #11... |
| Jun30-08, 01:16 AM | #15 |
10^x=e^(xln10)=e^x, so we are trying to find the derivative of e^x by the limit defination.
The math forum has a solution at: http://mathforum.org/library/drmath/view/60705.html |
| Jun30-08, 01:29 AM | #16 |
Sorry, the dereivative of 10^x is of course ln10(10^x) but the Math forum derivation of the derivative of e^x is still helpful
| Jun30-08, 04:45 AM | #17 |
More thoughts on this problem.
f(x)=10^X=e^(x*ln10) f(x+h)= e^(ln10(x+h))=e^(ln10*x)*e^(ln10*h) Plugging into definitation of derivative and simplifying gives f'(x)= limit(h goes to 0) 10^x(10^h-1)/h tabulating the limit as h goes to 0 of (10^h-1)/h= ln10 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Derivative of 10^x using limit definition
| solving for derivative of e^x using limit definition | Calculus & Beyond Homework | 19 | ||
| Using limit definition of multivariable derivative | Calculus | 2 | ||
| Definition of derivative | Calculus & Beyond Homework | 4 | ||
| Use definition of derivative | Calculus | 3 | ||
| definition of a derivative | Introductory Physics Homework | 2 | ||
