Help with Water, Ice, and metal finding temperature
The problem involves a thermal equilibrium scenario where ice is introduced into water contained in an aluminum vessel. The specific heat capacities of aluminum and water, along with the latent heat of fusion for ice, are provided. The objective is to determine the final equilibrium temperature of the system.
  • Mixed
  • Participants discuss the heat exchange between the ice, water, and aluminum container, attempting to set up equations based on heat lost and gained.
  • Some participants question the setup of the equations, particularly regarding the treatment of the different masses and temperatures involved.
  • There are attempts to express the heat gained by the ice and the heat lost by the water and container, with some participants seeking clarification on specific terms in the equations.
The discussion is ongoing, with various participants providing insights and corrections to each other's approaches. Some guidance has been offered regarding the need to separate terms for different components of the system, but no consensus has been reached on the final setup or solution.
Participants are navigating the complexities of heat transfer involving multiple substances at different initial temperatures, and there are indications of confusion regarding the correct formulation of the energy balance equations.
raymondmorrow
A 50-g of ice, initially at 0.0C, is dropped into 200 g of water in an 80-g
aluminum container, both initially at 30C. What is the final equilibrium
temperature? (Specific heat for aluminum is 900 J/Kg*C, the specific heat of
water is 4186 J/Kg*C, and Lf=3.33 X10^5).
I am trying to help my wife with this. I have no clue what to do. Can you help me find somewhere it will show me what I need to do?
Welcome to PF raymondmorrow,
What are your wife's thoughts on the question? What has she tried already?
heat lost by metal= M metal*C metal*change in temperature
heat gained by ice-water= (Q ice + Q water)+ m water*C water* change in temperature
heat lost by metal= heat gained by ice-water
I keep trying but I can't get the right answer (9.5 celsius) Any help is very appreciated.
Can you write this expression more explicitly? What are Q ice and Q water for example?
Heat lost by mutual:
(0.08kg)(900 j/kg*C)(30C-T)
=72 J/C(30C-T)
Ice to melt:
Q=(M ice)(lf)
=(0.05)(3.33x10^5)
=16650J
0.05kg * 0.2kg = 0.25kg
heat gained by water from ice:
(16650) + (0.25)(4.19 x 10 ^ 3)(T-0C)
16650+1047.5(T--0C)
16650+1047.5T
72 J/C(30C-T)=16650+1047.5T
2160-72J/CT=16650+1047.5T
-72 J/CT=14490+1047.5T (after subtracting 2160 from both sides)
-1195T=14490 (After subtracting 1047.5T from both sides)
=1.29
=72 J/C(30C-T)
Ice to melt:
Q=(M ice)(lf)
=(0.05)(3.33x10^5)
=16650J
16650+1047.5(T--0C)
16650+1047.5T
=1.29
You can't add the masses of the two waters, since they are at different initial temperatures and the 50 g of water is taking heat away from the 200 g of water and the container. You need separate terms for each one. You should have 4 terms to work with:
the heat gained by the 50 g of ice at 0 degrees to become water at 0 degrees (Q1 let's say)
the heat gained by the 50 g of water now at 0 degrees to get to Tf (Q2)
the heat lost by the 200 g of water in the container to get to Tf (Q3)
the heat lost by the aluminum container to get to Tf (Q4)
Your equation should be laid out like
heat used to melt the ice (Q1) and warm the 50 g of water (Q2) = heat lost by 200 g of water (Q3) and heat lost by container (Q4).
Put the terms in the right place and solve for Tf.
  • · Replies 17 ·
