How Do You Solve an Electromagnetism Problem Involving a Cylindrical Conductor?
  • Thread starter Thread starter cw88
    Electromagnetism
The discussion revolves around an electromagnetism problem involving a cylindrical conductor carrying an electrical current. The original poster seeks assistance in deriving the differential equations governing the motion of an electron escaping from the conductor's surface, while also considering the electric and magnetic fields generated by the conductor.
  • Participants discuss the use of Gauss's law and Ampere's circuital law to derive the electric and magnetic fields in cylindrical coordinates. There is an exploration of the Lorentz force and its application to the motion of the electron, leading to the formulation of a system of differential equations.
Some participants have provided guidance on the initial steps of the problem, affirming the approach taken by the original poster. There is an acknowledgment of the potential correctness of the derived equations, although explicit verification has not been completed. The discussion reflects a collaborative effort to clarify the setup and reasoning behind the equations.
The original poster expresses concern about the accuracy of their work and the need for precision to succeed in their course. There is a mention of the initial conditions and the specific coordinate system being used, which may influence the interpretation of the problem.
cw88
Hello, I'm new on this forum :)
I seriously need help with this problem. It has to be perfect if I want to pass the course, so I will really appreciate any solution to check my results.
An electrical current of 100[A] runs through a cilindrical conductor (radius 0.01[m], infinite length). The (axis of the) conductor is 2[m] above the earth, and it is held at a constant voltage of -1000[V] with respect to the ground.
1. Write the differential equations that describe the movement of an electron that escapes from the surface of the cable. Use a cartesian coordinate system whose x-axis coincides with the axis of the cable.
2. Solve the differential equations with the initial conditions x(0)=0, y(0)=0.01, and the electron starts at rest. (y(t) refers to the vertical axis)
That's it. I suppose you start by obtaining the magnetic induction and electric field and then use the Lorentz force on Newton's second law.
Sorry for my english if I made any mistake...
Thanks in advance.
... maybe this question is for the advanced physics forum, sorry for that :S
That's right, go ahead.
Allright. Using Gauss's law and Ampere's circuital law it's easy to obtain the fields (in cylindrical coordinates, with the vertical axis fixed at the conductor's axis and oriented in the current's direction):
[tex]\vec{B}=\frac{\mu_0 I}{2 \pi r}\hat{\phi}[/tex]
[tex]\vec{E}=\frac{\lambda}{2 \pi \epsilon_0 r}\hat{\rho}[/tex]
[tex]r > d[/tex] in both cases
To obtain [tex]\lambda[/tex] (charge per unit of length), we use the potential difference between the conductor's surface and the ground:
[tex]V(d) - V(D) = \int_\gamma \vec{E} \cdot \vec{dr} =<br /> \frac{\lambda}{2 \pi \epsilon_0} \int^D_d \frac{dr}{r} =<br /> \frac{\lambda}{2 \pi \epsilon_0} ln(D/d)[/tex]
Since [tex]V(D) = 0, V(d) = V[/tex]
[tex]\lambda = \frac{2 \pi V \epsilon_0}{ln(D/d)}[/tex]
Thus, the electric field is:
[tex]\vec{E} = \frac{V}{r ln(D/d)} \hat{\rho}[/tex]
Is it all right to this point?
Note:
  • d: conductor's radius
  • D: distance between the conductor's axis and the ground
  • V: voltage at which the conductor is held
  • I: the current that flows through the conductor
Using the stuff above, I've obtained a system of differential equations, but I don't know if it is correct...
I want to use Newton's second law, F=ma, being
[tex]\vec{F}=q( \vec{E} + \vec{v} \times \vec{B})[/tex]
the Loretz force that acts on the electron (of charge q and mass m).
Velocity in cylindrical coordinates is
[tex]\vec{v} = \dot{\rho} \hat{\rho} + \rho \dot{\phi} \hat{\phi} + \dot{z}\hat{k}[/tex]
Hence
[tex]\vec{v} \times \vec{B} =<br /> \frac{ \mu_0 I \dot{\rho} }{ 2 \pi \rho } \hat{k}<br /> - \frac{ \mu_0 I \dot{z} }{ 2 \pi \rho } \hat{\rho}[/tex]
[tex]\vec{F} = ( <br /> \frac{qV}{ \rho ln(D/d) } - <br /> \frac{ q \mu_0 I \dot{z} }{ 2 \pi \rho }<br /> ) \hat{\rho} + <br /> \frac{ q \mu_0 I \dot{\rho} }{ 2 \pi \rho } \hat{k}<br /> = m \vec{a}[/tex]
Writing the acceleration in cylindrical coordinates, we obtain the following equations:
[tex]1.\qquad \frac{qV}{ \rho ln(D/d) } - <br /> \frac{ q \mu_0 I \dot{z} }{ 2 \pi \rho } = m \ddot{\rho}[/tex]
[tex]2.\qquad 2 \dot{\rho} \dot{\phi} + \rho \ddot{\phi} =<br /> \frac{d}{dt} ( \rho^2 \dot{\phi} ) = 0[/tex]
[tex]3.\qquad \frac{q \mu_0 I \dot{\rho}}{2 \pi \rho} = m\ddot{z}[/tex]
From the second equation, since the electron starts with no velocity at all:
[tex]\rho^2 \dot{\phi(t)} = \rho^2 \dot{\phi(0)} = 0 \qquad \forall t[/tex]
[tex]\qquad \Rightarrow \phi(t) = c[/tex]
Being c an arbitrary constant. Here I choose c = 0 for simplicity. This way the transformation to the asked coordinate system is trivial.
I'm really bad at this, so it would be a big achievement to me if it's correct to this point :D
I didn't check everything explicitly, but your procedure is fine, so if you haven't made some trivial error, the equations should be correct.
thanks a lot, from this point it's not very hard to find the equations... I'm an expert at trivial errors, so wish me luck...
Good luck.
  • · Replies 64 ·
  • · Replies 19 ·
