Car Following Models: Explaining Older Models
  • Thread starter Thread starter aldous
    Car Models
This discussion centers on the complexities of older car following models in traffic simulation, specifically referencing the Intelligent Driver Model (IDM) and equations from Jiménez et al. (2000) and Treiber et al. (2000). Key variables such as \dot{x}_f^m and \lambda are clarified, with m and l representing parameters that influence driving behavior rather than physical attributes like mass. The discussion concludes that \lambda serves as a proportionality factor, essential for understanding the dynamics of vehicle interactions in these models.
  • Understanding of traffic simulation concepts
  • Familiarity with mathematical modeling in physics
  • Knowledge of the Intelligent Driver Model (IDM)
  • Basic grasp of differential equations
  • Research the mathematical foundations of car following models
  • Explore the implications of parameters m and l in traffic behavior
  • Study the differences between various car following models, including IDM and older models
  • Investigate the role of proportionality factors in dynamic systems
Traffic simulation developers, computer science students, researchers in transportation engineering, and anyone interested in the mathematical modeling of vehicle dynamics.
aldous
Hello,
I'm a computer science student in desperate need for help. In the process of writing my master's thesis I've successfully developed a traffic simulation using a model I've found in the traffic research literature, the IDM, to be precise. This model seems straight-forward and is easy to grasp even for a dim mind like mine.
However, I fail to understand older car following models, such as presented by http://www-sop.inria.fr/mascotte/Philippe.Mussi/papers/esm2000.ps" and
http://arxiv.org/PS_cache/cond-mat/pdf/0002/0002177v2.pdf" ... Hopefully just because I simply don't know what some variables mean, which are apparently not introduced.
Jiménez et al. (2000) state that all car following models can be summarized by:
[tex]\ddot{x}_f ( t+T_r ) = \lambda * [ \dot{x}_{l}(t) - \dot{x}_{f}(t)] \quad (1)[/tex]
[tex]\lambda = \frac{a_{l,m}* \dot{x}_{f}^m(t+T)}{[x_{l}(t)-x_{f}(t)]^l} \quad (2)[/tex]
So my questions: what does [tex]\dot{x}_f^m[/tex] express? Sure, [tex]\dot{x}_f[/tex] is the velocity of vehicle [tex]f[/tex], but what is [tex]m[/tex]? The vehicle's mass? Why would one want to potentiate the velocity by the mass? I'm lost! Further, I interpreted [tex]l[/tex] -- being used as an index in equation 1 -- as the leading car, [tex]f[/tex] denoting the following car. However, in equation 2, [tex]l[/tex] is used as a power? How is this to be interpreted?
Similarly, Treiber et al. (2000) state that older car following models can be reduced to that formula:
[tex]\dot{v}_\alpha ( t+T_r ) = \frac{-\lambda v_\alpha^m \Delta v_\alpha}{s_\alpha^l} \quad (3)[/tex]
My question: the [tex]\lambda[/tex] in eq. 3 seems to be different to the [tex]\lambda[/tex] in eq. 2. Is it this a variable often used in physics one should just know? (It is not defined in the paper)
Thank you very much in advance for any pointers!
Alexander
Well, my questions are answered in http://www.easts.info/on-line/journal_06/1354.pdf"
[tex]m,l[/tex] are -- when used as powers -- simply parameters influencing the driving behavior, [tex]\lambda[/tex] is just any proportionality factor.
Thanks anyway,
Alexander
  • · Replies 36 ·
  • · Replies 0 ·
