Solution of System of Equations: [Lambda] = 3/(2x)
The discussion revolves around solving a system of equations involving the variable λ, expressed as λ = 3/(2x) = 1/(2y) = 1/(3z), along with a constraint equation x² + 2y² + 6z² = 1. Participants are exploring methods to find the values of x, y, and z that satisfy these equations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Some participants suggest expressing x, y, and z in terms of λ and substituting into the constraint equation. Others question whether λ is constant and discuss the implications of that assumption. There are attempts to set the equations equal to each other to derive relationships between x, y, and z.
The discussion is active, with participants providing guidance on how to approach the problem. There is recognition of the complexity involved in simplifying the expressions for x, y, and z, and some participants express uncertainty about their algebraic manipulations. Multiple interpretations of the problem setup are being explored.
Participants note that this is a Lagrange multiplier problem, and there is a constraint equation that must be satisfied. Some express confusion about their calculations and seek to clarify their understanding of the relationships between the variables.
snoggerT
[lambda]=3/(2x) = 1/(2y) = 1/(3z) with constraint eq. x^2+2y^2+6z^2=1
- I can't figure out how to solve this system of equations. Can somebody please help.
Is [tex]\lambda[/tex] supposed to be constant? If so, then it appears simple. Just Express x,y,z in terms of lambda, substitute it into the constraint equation and solve for lambda.
- yeah, that's way simpler than I was making it. So I would take lambda and plug back into find my x, y, z, right?
Yes that's right.
Defennder said:
Yes that's right.
- so I get lambda to be +/- sqrt(41/12), which can be reduced to +/- 1/2*sqrt(41/3), but that gets somewhat ugly when plugging back into find my x,y,z. I'm trying to find the min/max on this problem, so I have to find my x,y,z to plug back into the f(x,y,z) function. Is there any way to simplify things further?
Wait wait! You're solving for lambda?
[tex]\lambda=\frac{3}{2x}[/tex]
[tex]\lambda=\frac{1}{2y}[/tex]
[tex]\lambda=\frac{1}{3z}[/tex]
Set them equal to each other so that you have y = ... in terms of x and z = ... in terms of x so you can plug it back into your equation to solve for x.
- so I get +/- sqrt(27/41) for x, is that right?
Hmm, what did you do?
- I set 3/(2x)= 1/(2y) and got y in terms of x and did the same for z. then plugged into the constraint equation and solved for x. I'm guessing I did it wrong though.
[tex]y=\frac x 3[/tex]
[tex]z=\frac 2 9 x[/tex]
- that's what I got for y and z, so I must of done something wrong with my algebra in the constraint equation. Let me work it again.
I still get x=+/- sqrt(27/41). So I'm not sure what I'm doing wrong. This is how I'm setting the problem up:
x^2+2(x/3)^2+6(2x/9)^2=1
This is a lagrange multiplier problem isn't it? Can you state the original problem?
- sure. I probably need to start over anyways because I think I'm just confusing myself.
find the min/max:
f(x,y,z)=3x+2y+4z with constraint equation x^2+2y^2+6z^2=1
Ok, I think you are on completely the right track. lambda^2=12/41 is what I get too. And yes, x=+/-sqrt(27/41). I'll admit the numbers aren't that pretty. But I think you are doing exactly the right thing. Just keep on doing it.
