Another Measurement of Speed of Light
The forum discussion centers on an experiment measuring the speed of light using Fizeau's apparatus, where the distance between the light source and mirror is 11.45 km and the wheel has 720 notches. The calculated speed of light was 2.889 x 10^8 m/s, with a derived minimum angular speed of the wheel at 57.12 rad/s. A correction was noted regarding the angular displacement, where the correct value for theta should be 1/720 rev instead of 1/440 rev, leading to the accurate answer of 114 rad/s as per the textbook.
  • Understanding of Fizeau's method for measuring the speed of light
  • Familiarity with angular velocity and its calculations
  • Knowledge of basic physics equations related to speed and time
  • Ability to perform unit conversions and dimensional analysis
  • Study the principles of Fizeau's experiment in detail
  • Learn about angular velocity calculations in rotational motion
  • Explore the derivation and application of the equation c = 2d/t
  • Investigate common errors in experimental physics calculations
Physics students, educators, and anyone interested in experimental methods for measuring fundamental constants like the speed of light.
clairez93
In an experiment to measure the speed of light using the apparatus of Fizeau, the distance between light source and mirror was 11.45 km and the wheel had 720 notches. The experimentally determined value of c was 2.889 x 10^8 m/s. Calculate the minimum angular speed of the wheel for this experiment.
c = 2d/t
t = theta/w
2.998 x 10^8 m/s = 2(11450m) / t
t = 7.638 x 10^-5 s
7.368 x 10^-5 = (1/440 rev) / w
w = 9.091 rev/s
9.091 * 2pi = 57.12 rad/s
Book answer: 114 rad/s
Sorry about the earlier empty message; I hit enter too early. I am not sure what mistake I have mdae in my calculations, and if someone could look it over and help me, it would be greatly appreciated.
Why is [itex]\theta[/itex] equal to 1/1440 rev (I think that's what you meant). If there are 720 notches, then [itex]\theta=1/720[/itex] rev. That will give you the right answer.
  • · Replies 42 ·
  • · Replies 27 ·
  • · Replies 146 ·
11K
