Testing for Convergence or Divergence of 3/n
The discussion revolves around determining the convergence or divergence of the series from n=1 to infinity of 3/n, which is identified as a harmonic series.
  • Exploratory, Assumption checking
  • Participants explore the use of the Test for Divergence and question its applicability, noting that a limit of zero does not provide definitive information about convergence.
Some participants have provided clarifications regarding the nature of the series and the limitations of the Test for Divergence, suggesting that further analysis may be necessary.
The original poster expresses uncertainty about the approach taken, and there is a recognition that the series is not geometric but rather harmonic.
Rossinole
Is the series from n=1 to infinity of 3/n converging or diverging?
Since 3/n is not a geometric series, my guess is that we can just use the Test for Divergence and take it's limit to see if it's converging or diverging. As n->infinity, 3/n -> 0 and lim = 0, so it's converging.
However, I am not sure if this is right way to go about it.
Correct.
Not a bad guess, but beware that the Test for Divergence cannot tell you if a series converges (hence, its name).
Wrong. The Test for Divergence says that:
[tex]\lim_{n\rightarrow\infty}a_n \neq 0 \Rightarrow \sum_{n=1}^\infty a_n[/tex] diverges.
Equivalently, it says that:
[tex]\sum_{n=1}^\infty a_n[/tex] converges [tex]\Rightarrow \lim_{n\rightarrow\infty}a_n = 0[/tex]
If the limit is zero, then the test yields no information and you have to use another test.
So I would have to treat it as a Harmonic Series?
It is a harmonic series.
Alright, thank you for your help.
