Is the spectrum of a BPSK signal symmetrical about the carrier frequency?
  • Thread starter Thread starter dimensionless
    Signal Spectrum
The discussion centers on the spectral characteristics of Binary Phase Shift Keying (BPSK) signals, specifically whether the spectrum is symmetrical about the carrier frequency. Participants explore theoretical and practical aspects of BPSK signal modulation and its frequency spectrum, including simulations and empirical observations.
  • One participant's simulation of a BPSK signal indicated an asymmetrical spectrum with peaks only above the carrier frequency, contradicting claims from peers with PhDs in digital communications.
  • Another participant referenced a source indicating that the amplitude spectrum of BPSK signals is that of a double-sideband suppressed-carrier signal, suggesting symmetry.
  • A different participant presented spectra of BPSK signals showing symmetry about the carrier frequency and questioned whether the original simulation was conducted at RF or baseband.
  • One participant argued that the power spectrum of a BPSK wave is symmetric, supported by a mathematical explanation involving Fourier transforms and the nature of the modulation sequence.
  • Another participant noted that the abrupt phase changes in BPSK signals do not lead to frequency components lower than the carrier frequency.
  • A later reply emphasized that in the complex signal domain, both positive and negative frequencies exist, leading to a spectrum that surrounds the carrier frequency.
Participants express conflicting views regarding the symmetry of the BPSK spectrum. While some argue for symmetry based on theoretical principles and empirical observations, others maintain that their simulations suggest asymmetry. The discussion remains unresolved with multiple competing perspectives.
Participants highlight potential limitations in the simulation setup, such as whether the BPSK signal was modulated to RF or remained at baseband, which may influence the observed spectral characteristics.
dimensionless
I did some simulations where I created a BPSK signal, and then found the spectrum of the signal. The spectrum had a peak at the carrier frequency. It also had peaks at regular intervals frequencies higher than the carrier frequency. There were no peaks at frequencies lower than the carrier frequency.
People around me, people who have PhDs in the field of digital communications give me conflicting information. They tell me that there are spectral peaks on both sides of the carrier frequency. In other words, they say that the spectrum is symmetrical about the carrier frequency. This outright contradicts my simulation, and I don't think that it can be proven any other way than by doing a simulation, and I'm generally better and simulation and spectral analysis than they are.
Can anyone confirm or deny that the spectrum of a BPSK wave is indeed asymmetrical about the carrier frequency?
Don't know much about BPSK, but
this -> http://www.elec.mq.edu.au/~cl/files_pdf/elec321/lect_mpsk.pdf
Figure 23.3 shows the amplitude spectrum of the BPSK signals when m(t) is a periodic
pulse train. The spectrum of the BPSK signals is that of a double-sideband suppressedcarrier
signal.
Edit: so it would not be asymmetrical.
Here are some spectra of a BPSK signal. Note the 1st, 2nd and last plot, the spectra all have symmetry about the central transmitting frequency.
I have transmitted/received BPSK over the airwaves, though I never took a close look at the frequency spectra before. I was more interested in encoding/decoding the content of the transmission. In your simulation, did you modulate the BPSK signal to RF or did you do it at base band?
If you mean power spectrum, it is symmetric as seen by calculating it. The signal is
[tex]s(t)=e^{i\pi x_n}cos(\omega t)[/tex]
where the binary modulation sequence [tex]x_n[/tex] consists of 1's and 0's during time intervals [tex]nT \leq x < (n+1)T[/tex].
The exponential term simply switches between -1 and 1, so we can rewrite write the signal [tex]s(t)=y_n cos(\omega t)[/tex] in terms of a related modulation sequence [tex]y_n=2x_n-1[/tex].
It follows that the transform [tex]S(\omega)=\mathcal{F}\{s(t)\}[/tex] is a convolution of transforms of the parts, [tex]S(\omega)=\mathcal{F}\{y_n\}\star\mathcal{F}\{cos(\omega t)\}[/tex]. So the RF spectrum is the spectrum of the modulation translated to the carrier frequency.
Now for the key part: y is purely real so its Fourier transform is conjugate anti-symmetric, that is, [tex]\mathcal{F}\{y_n\}=Y(\omega)=Y^{*}(-\omega)[/tex] (see Bracewell or any other book on Fourier transforms). If you calculate the complex transform, then, the real part is symmetric and the imaginary part antisymmetric. It is unusual, however, to look at the complex spectrum. One usually considers the power spectrum, and that indeed is the only thing measured in the lab. The power spectrum for the present case
[tex]|Y(\omega)|^2=|Y(-\omega)|^2[/tex]
is strictly symmetric.
So the power spectrum, which is what is commonly meant by "spectrum", must be symmetric about the carrier.
As for NoTime's quote, the carrier is suppressed only in the special case of a square wave modulation. In general the carrier is present.
My signal is just a BPSK (or QPSK) signal. The bits are randomly encoded.
What I don't yet see, is how the abrupt phase changes would cause the signal to have frequency components that are lower than the carrier frequency.
In the complex signal domain, both positive and negative frequencies are allowed. The spectrum of your discontinuous binary information has high frequencies of both signs. When you modulate the carrier with the signal, its spectrum surrounds the carrier both above and below.
  • · Replies 41 ·
  • · Replies 0 ·
