Why is a space probe spinning around its own axes, when flying through space?
The discussion revolves around the reasons why space probes spin around their own axes while traveling through space. It touches on various aspects including thermal management, stability, and the effects of environmental factors in space.
  • Some participants suggest that spinning helps prevent overheating of sensitive components by ensuring that no single side faces the sun continuously.
  • Others propose that rotation allows probes to take readings in different directions, enhancing their observational capabilities.
  • One participant notes that probes flying out of the solar system also exhibit spinning behavior, prompting questions about the underlying reasons.
  • It is mentioned that rotation might be related to the propulsion system or the need to orient instruments like telescopes.
  • Another participant raises a point about the minimal resistance in space, questioning the analogy with a spinning bullet.
  • One contribution highlights the gyroscopic effect, suggesting that spinning increases stability in motion along the axis of rotation.
  • A participant discusses the aerodynamic considerations, even in the low-density environment of space, and mentions the impact of gravity gradients on non-spherical satellites.
  • Thermal management is also brought up, with the idea that rotation helps prevent hot spots due to radiation pressure on solar panels.
  • It is noted that not all satellites rotate, with examples like Hubble and the ISS provided, indicating that rotation is not universally necessary.
Participants express a range of viewpoints on the reasons for spinning, with no consensus reached on a singular explanation. Multiple competing theories and considerations are presented.
Some arguments depend on specific definitions of terms like "aerodynamic," and the discussion includes various assumptions about the effects of environmental factors in space. The role of rotation in different types of satellites remains unresolved.
Bjarne
Astronomy news on Phys.org
If one side was facing the sun all the time it would get very hot and sensitive components could get damaged. Also it could be usful so the probe could take readings etc in different directions.
So fare I know, also probes flying out of the solar system is also spinning
Why ?
Probably to move their telescopes etc it face different positions, it might be something to do with their propulsion system.
This was also what I was thinking, - but resistance is almost zero.
I mean we can not compare the liogic with a spinnng bullet ?
Hmm..I'd said it is due to the gyroscopic effect:
An object that spins around its axis of motion will be more STABLE in its motion along that axis.
That means it will keep its intended motion more easily.
Here are a few reasons:
Heh... I thought the answer would be obvious, until I tried to find a website.
Even for deep-space probes, space is not a perfect vacuum, so rotation makes sense for aerodynamic (is that term still applicable?) reasons. Yes, the density is very low but the flight duration is very long.
Also, in low Earth orbit, the effect of the gravity gradient is sufficient to apply a torque to non-spherical satellites, which require rotation as a stabilizing mechanism.
Solar panels cause a torque to be exerted from radiation pressure, and in terms of thermal management, it makes sense to rotate the satellite to prevent a hot spot from occurring.
That said, there are plenty of satellites that don't rotate: Hubble, the ISS, WMAP, etc.
  • · Replies 40 ·
  • · Replies 39 ·
  • · Replies 53 ·
9K
  • · Replies 27 ·
  • · Replies 0 ·
11K
  • · Replies 19 ·
