Centroid of a Solid (triple integral)
The discussion focuses on calculating the centroid of a tetrahedron in the first octant defined by the equation x + y + z = 1. The user initially attempts to compute the x-coordinate of the centroid using the formula xcenter = (∫∫∫_G x dV) / V but encounters an issue where the volume integral evaluates to zero, leading to an undefined expression. A fellow user suggests correcting the bounds of integration, specifically changing the limits for y to integrate from 0 to (1 - x), which resolves the issue and aligns with the expected centroid coordinates of (1/4, 1/4, 1/4).
  • Understanding of triple integrals in calculus
  • Familiarity with the concept of centroids in geometry
  • Knowledge of integration limits in multiple dimensions
  • Experience with evaluating volume integrals
  • Review the calculation of centroids for various geometric shapes
  • Practice solving triple integrals with different bounds
  • Learn about the application of centroids in physics and engineering
  • Explore advanced integration techniques such as change of variables in multiple integrals
Students in calculus, geometry enthusiasts, and anyone studying applications of triple integrals in physics or engineering will benefit from this discussion.
Knissp
Find the centroid of the solid:
the tetrahedron in the first octant enclosed by the coordinate planes and the plane x+y+z=1.
xcenter = [tex]\frac{\int\int\int_G x dV}{V}[/tex]
ycenter = [tex]\frac{\int\int\int_G y dV}{V}[/tex]
zcenter = [tex]\frac{\int\int\int_G z dV}{V}[/tex]
I have shown my attempt for xcenter, as the same problem arises for each one.
[tex]\frac{\int_{x=0}^1\int_{y=0}^1\int_{z=0}^{1-y-x} x dzdydx}{\int_{x=0}^1\int_{y=0}^1\int_{z=0}^{1-y-x} dV}[/tex]
but [tex]\int_{x=0}^1\int_{y=0}^1\int_{z=0}^{1-y-x} dV[/tex] is equal to zero,
so the above expression is undefined.
According to my text, the answer should be (1/4,1/4,1/4). Could someone point out what I did wrong? (Perhaps my bounds of integration?)
Hi Knissp! :smile:
Try [tex]\int_{x=0}^1\int_{y=0}^ {1-x}\int_{z=0}^{1-y-x}[/tex] :wink:
Oh, I see now! Thank you!
  • · Replies 19 ·
