Matrix multiplication of an nxn matrix is the scaling
The discussion centers on the geometric interpretation of matrix multiplication, particularly focusing on the properties and relationships of an nxn matrix and its inverse. Participants explore concepts related to transformations, reflections, and the dimensionality of the spaces involved.
  • Some participants propose that matrix multiplication of an nxn matrix involves scaling and rotation of vectors in n dimensions, questioning the nature of the inverse matrix as a transformation that results in a unit vector in transformed space.
  • Others discuss the relationship between a matrix and its inverse, suggesting that the inverse matrix may have a reflection-like relationship similar to inverse functions in 2D space.
  • One participant questions the feasibility of graphing matrices and their inverses, noting that an nxn matrix operates in an n^2 vector space, implying the need for higher-dimensional graphs.
  • Another participant suggests that while each row or column of a 3x3 matrix can be viewed as a vector, the representation of these vectors in relation to planes is complex and may not be straightforward.
  • Some participants explore the idea that the vectors corresponding to a matrix and its inverse might have a correlation, although the nature of this relationship remains unclear.
  • There is a discussion about the graphical representation of functions and their inverses, with some participants noting that while visual aids are useful in lower dimensions, they become less practical in higher dimensions.
  • One participant provides a method for writing a matrix that represents the graph of an inverse function, suggesting a technique involving Gaussian elimination to derive points on the graph of the inverse.
Participants express a range of views on the geometric interpretation of matrices and their inverses, with no clear consensus on the relationships or implications of these concepts. The discussion remains unresolved regarding the exact nature of the relationships between matrices and their inverses.
Limitations include the complexity of visualizing higher-dimensional graphs and the assumptions made about the relationships between matrices and their inverses. The discussion also highlights the challenges in representing transformations and reflections in higher-dimensional spaces.
chaoseverlasting
Geometrically, matrix multiplication of an nxn matrix is the scaling, and rotation of a vector in n dimensions true? So when you find the inverse of a matrix, what you're actually doing is finding a transformation such that in the 'transformed space' the vector is a unit vector.
If the inverse matrix ([tex]A^{-1}[/tex])is plotted in the original space, then does it have any relation to the original matrix([tex]A[/tex])?
What I mean by that is, if you have a function [tex]y=f(x)[/tex] in 2 D space, and you find the inverse function [tex]x=f^{-1}(y)[/tex] the inverse function is a reflection of the function [tex]y=f(x)[/tex] about the line [tex]y=x[/tex]. Does the inverse matrix ([tex]A^{-1}[/tex]) have any such relation to the original matrix([tex]A[/tex])?
The relation between [tex]A^{-1}[/tex] & [tex]A^[/tex]... the inverse of [tex]A^[/tex], where it exists, is denoted by [tex]A^{-1}[/tex] and [tex]AA^{-1}[/tex] is equal to I ie. identity matrix = [tex]A^{-1}A[/tex]
True, but I don't believe that was the question he was asking.
What do you mean by "plotted in the original space"? An n by n matrix operates on n dimensional vectors and itself exist in an n2 vector space. In order to "graph" A and A-1 you would need an n4 dimensional graph.
Why would you need an n4 dimensional graph? Say for a 3x3 matrix, you would need a 9 D space then. Its kind of hard for me to imagine that, but say if we took each row or column to be a plane in 3D (where I suppose each plane corresponds to a projection of 9D space on 3D), would there be a relation between the planes of [tex]A[/tex] and [tex]A^{-1}[/tex] ?
A plane? Wouldn't each row or column of a three by three matrix simply be a vector in [tex]F^3[/tex]?
Yeah, each row or column of a 3x3 matrix would be a vector, but if you assume that vector to be the normal vector passing through a given point then you get three planes depending on whatever matrix equation you use. I don't think a standalone 3x3 matrix could represent planes by itself.
Even so, I'm guessing here, the projection would give you three vectors instead of three planes. So you would have a set of three vectors corresponding to [tex]A[/tex] and three vectors corresponding to [tex]A^{-1}[/tex], would the vectors of A and A-1 be co-related in any way?
Anyone? Please :p ?
In general, any function (including e.g. matrices) [tex]f:R^n\rightarrow R^n[/tex] has a graph in [tex]R^{2n}[/tex] which is the set [tex]\{(\textbf{x},f(\textbf{x})):\textbf{x}\in R^n\}[/tex]. If f is invertible then the graph of [tex]f^{-1}[/tex] is [tex]\{(f(\textbf{x}),\textbf{x}):\textbf{x}\in R^n\}[/tex]. You get one from the other by reflection through a hyperplane and you can easily write out the matrix for this.
For a function on R this is very usefull as a visual aid. In general, not so. I think what you want to know is if we can read off the value that A^{-1} assigns to x using the graph of A? Because we can't visualise the graph we can't.
Thats exactly it. How would you go about writing a matrix for this? Perhaps we can't use it as a visual aid, but it would simplify a lot of other calculations.
Use
[tex]B:=\left[ \begin{array}{cc} 0 & I \\<br /> I & 0 \end{array} \right][/tex]
where I is the identity on [tex]R^n[/tex]. The coordinates of a general point on the graph are [tex](Ix,Ax)[/tex], so the coords of a general point on the graph of the inverse are [tex]B(Ix,Ax)=(Ax,Ix)[/tex]. One usually writes out the matrix [tex](A,I):R^n\rightarrow R^{2n}[/tex] and uses gaussian elimination to convert it to [tex](I,A^{-1})[/tex], which again gives points on the graph of the inverse, but in a more useful fashion.
  • · Replies 33 ·
