Is the Chart Box Plan Feasible for Utilizing Telephone Line Power?
  • Thread starter Thread starter MrMedeco
    Box Work
The discussion revolves around the feasibility of a "chart box" designed to extract power from telephone lines. Participants explore the technical aspects of the design, including voltage levels, power transmission, and potential modifications to improve functionality. The conversation includes considerations of energy conservation and the practicality of the proposed approach.
  • One participant expresses skepticism about the simplicity of the chart box design and questions its effectiveness in leeching electricity from telephone lines.
  • Another participant mentions the principle of conservation of energy, suggesting that the power output cannot exceed the power input, and raises concerns about the adequacy of 24 gauge wires for power transmission.
  • Concerns are raised about the parts list, particularly regarding the specification of fuses and the voltage levels involved, with one participant noting that they have only encountered fuses rated by current.
  • There is a discussion about the voltage on telephone lines, with one participant claiming it is approximately 130 V, while another asserts it is typically 40 V, increasing to 90 V during ringing.
  • Some participants agree that while it may be possible to extract some power from the phone line, the amount would likely be minimal and could risk damaging the phone company's equipment.
  • Suggestions are made for improving the design, such as incorporating a voltage regulator or zener circuit to manage output impedance more effectively.
Participants exhibit disagreement regarding the voltage levels of telephone lines and the overall feasibility of the chart box design. While some acknowledge the possibility of extracting power, there is no consensus on the effectiveness or safety of the proposed method.
Participants express uncertainty about specific voltage levels and the adequacy of the proposed components, indicating a lack of clarity in the original design's specifications and assumptions.
MrMedeco
Hello, I am a beginning electronics hobbiest who needs a quick answer. My question is, would these plans for a "chart box" really work?
http://www.textfiles.com/phreak/BOXES/chartreu.box
If not, would there be other possibilities that will work? The main purpose of the chart box is too leech electricity from the telephone line and apply it to whatever you need it for.
I don't think this will work, as the plan seems way too simple and your dealing with low voltage DC. However, I would like a professional opinion. Any insight into this is greatly appreciated. Thanks
This is simple conservation of energy. Power output !> power input. Dinky 24 gauge wires don't seem to lend themselves to great power transmission do they?
Reminds me of the time I read about compromising the network of a large retail chain's computers using the handheld scanners in the stores. Since I worked at HQ I knew the equipment in question and the article was quite amusing in how far off it was from reality. Had the author actually accomplished 1/10th their objective, along the way they would have realized their mistakes in their 'theory' and found a MUCH easier method.
Cliff
- The parts list smells suspicious, but perhaps I just never ran into a fuse specified for a voltage (I always dealt with fuses with current specifications).
- It says you can get more voltage if you use a transformer, but I'm pretty sure that these lines are primarily DC, so you would need to supplement the transformer with a switcher.
- The basic (and I do mean basic) idea behind the design is reasonable. Obviously, there is power delivered over the phone line, otherwise all phones would need to be plugged into a 120 outlet. From my experience working in the telecom industry, the voltage in the phone line is ~130 V (I'm pretty sure that's constant, though it may just be upon ring). In principle, you should be able to drive a load in parallel to the line, but as has been mentioned, I don't believe you will get much power. The description (if not the design itself) given on that web page is very sloppy.
I'm rather sure the normal voltage supplied to a phone is 40V, and 90V on ring.
I agree with all of the above -- you could certainly leech some power (to light the buttons on your handset, for example), but you wouldn't be able to leech much. At some point you'd blow one of the phone company's fuses.
- Warren
I'm not surprised that I am mistaken. I can't remember where that 130 V figure came from; somewhere in the lab I'm sure. I definitely remember a 48 V ((ter)) ((min)) ((al)). Anyway, I think it would be a much better design to use a voltage regulator circuit, or at least a zener circuit. The rheostat would kill the output impedance (assuming it's even good to begin with, which I imagine is not true).
How could a fuse ever be setup to blow at a certain voltage level for protection without knowing the load or current? The lack of mentioning using something like a zener or linear regulator in the author's text tells the tale...
Huh, I didn't know it was 90V at ring, maybe time to get out the scope and call myself! :smile:
Cliff
  • · Replies 0 ·
