Proof of a result inside a lemma?
  • Context: Graduate
  • Thread starter Thread starter tgt
    Proof
The discussion revolves around the structure and presentation of mathematical proofs, particularly focusing on the concept of having a proof of a claim within a lemma that is itself part of a theorem. Participants explore the implications of nested statements and the organization of proofs in mathematical writing.
  • Some participants question the commonality of having nested statements, such as lemmas within theorems, suggesting it may not be standard practice.
  • One participant proposes a typical structure for presenting a theorem, emphasizing that proofs should not depend on subsequent statements and suggesting a clearer order of presentation.
  • Another participant offers several options for handling proofs within lemmas, including making them separate lemmas, proving them inline, or deferring the proof to the end.
  • There is a humorous suggestion about leaving a proof as an exercise for the reader or grader, indicating a playful approach to the issue.
  • Some participants debate whether a sublemma should have its own title or simply be part of the proof of the containing lemma, questioning the necessity of separate labeling.
  • It is noted that if a proof of a claim within a lemma is significant enough, it could be classified as a "sub-lemma," although the term "sub-lemma" is not widely used in literature.
  • Concerns are raised about the motivation behind nesting proofs and whether such a structure is justified, with some arguing for a more sequential presentation of results.
Participants express differing opinions on the appropriateness of nested proofs and the structure of mathematical documents. There is no consensus on whether sublemmas should be formally recognized or how they should be presented.
Limitations in the discussion include varying definitions of what constitutes a lemma or sublemma, and the absence of a clear standard for organizing nested proofs in mathematical writing.
tgt
What do you call a proof of a claim inside a lemma? And that lemma is inside a theorem.
As I already indicated in this thread you might want to revise your document structure. I don't think it is common to have nested statements (like lemma's inside theorems) at all.
The normal presentation for this would go something like:
Statement of Theorem
Comment that to prove the theorem we will use some simple lemmas
Statements and proofs of lemmas
Restatement of theorem, or just a statement that theorem X above now follows.
You should avoid a cascade of statements whose proofs depend on the following statements. Instead put the thing you prove first at the top, and perhaps precede with a comment such as 'we will use the following small result later', and then reference it when you do you use it.
What happens if you need to prove something inside a lemma?
Depending on how important it is and how large the proof is, you have three options IMO:
  • Make it a separate lemma which you prove separately, and refer to in the main proof.
  • Prove it "inline", e.g. in a new sentence or even in brackets, right after giving the statement.
  • Mention the statement and defer the proof to the end ("This concludes the proof of the statement, it just remains to show [... conclusion which you had already used ...] -- which we shall do now."
Or if you're feeling particular wicked just insert the statement:
The proof is left as an exercise to the reader.
In exams you might want to try the following variant:
The proof is left as an excerise for the grader.
Does the sublemma even merit a title? Why can't it just be part of the proof of the containing lemma? If this lemma requires another result to be proven before it, then why is it a lemma itself? Why not put the sublemma first as another lemma? You have been given many alternatives.
It certainly could, just as subroutines could be included in the computer program where they are called. A "lemma" is just a part of the main proof that is simpler to understand if it is done separately. The same could be true of a "sub-lemma".
If I am reading the original post correctly, a "proof of a claim inside a lemma", if it is written as a separate proof, would, indeed, be a "sub-lemma".
If the "sub-lemma" is a really small result, one will often just put "Claim: xxx" Then "Proof of Claim:" in the middle of the proof of the lemma. If it's a result that will be used later in the paper, it deserves its own "Lemma" status. I have never read a paper that refers to "sub-lemmas". But then again I'm sure they are out there.
No one is disputing that, Halls, merely the OP's motivation for doing it and his desire both for the numbering (see parallel thread) and the wish to nest 3 proofs inside each other, rather than have them run sequentially: this subresult appears to be so pivotal as to merit its own number (and indeed counter). At which point you might wish to ask if it needs to stand alone as a separate statement.
  • · Replies 0 ·
  • · Replies 17 ·
