| Thread Closed |
Stress energy tensor of a rotating hoop |
Share Thread |
| Jul17-08, 12:46 AM | #1 |
This problem comes from the GR problem book, question 5.1 (b).
The setup is a ring of N identical masses rotating in the x-y plane at a distance [latex]a[/latex] from the origin. Assume that N is large enough so the ring may be treated as continuous. Ignore the stress energies keeping the particles in orbit. According to the solution, the energy density of the ring is [latex]T^{00} = \frac{Nm\delta(r - a)\delta(z)}{2\pi a\gamma}[/latex]. I'm having trouble understanding why this is the case. It is certainly true that for a stationary ring the rest-energy density is [latex]\rho_0 = \frac{Nm\delta(r-a)\delta(z)}{2\pi a}[/latex] which can be easily seen by integrating over all of space in cylindrical coordinates. Alternatively it can be shown using the fact that [latex]\rho_0 2\pi r dr dz = Nm[/latex] and then dividing through by the infinitesimal [latex]2\pi r dr dz[/latex]. Why would it be that the energy density decreases as the angular velocity is increased? |
| Jul17-08, 12:55 AM | #2 |
It looks like I must have miss-read the solution. I think the idea is to realize that since there is no change to the volume of the ring, the rest-energy density picks up a factor of [latex]\gamma[/latex] as opposed to [latex]\gamma^2[/latex] which would be the case for a contracted rod e.g.
| Jul17-08, 06:37 AM | #3 |
Regards, Bill |
| Jul17-08, 06:55 AM | #4 |
I thought perpendicular motion is unaffected by Lorentz contraction? Since the radius is everywhere perpendicular to the direction of motion it should remain constant and consequently so should the circumference?
| Jul17-08, 07:03 AM | #5 |
Regards, Bill |
| Jul17-08, 07:08 AM | #6 |
True, but I can't seem to reconcile this with the radius problem. Clearly one quantity can't change without affecting the other.
In any case, if what you purport is true, then the factor of [latex]\gamma[/latex] on the denominator would cancel the [latex]\gamma[/latex] coming from the energy implying that the energy density is independent of angular velocity (false). |
| Jul17-08, 07:15 AM | #7 |
For reference, the expression given for [latex]T^{00}[/latex] in the book is
[latex]T^{00}= \frac{\gamma Nm\delta(r-a)\delta(z)}{2\pi a}[/latex]. What I can't understand is why they claim that [latex]\rho_0 = \frac{Nm\delta(r-a)\delta(z)}{2\pi a\gamma}[/latex] (note the gamma on the denominator). Surely the rest-mass density should be independent of gamma as I indicated in the OP. |
| Jul17-08, 08:05 AM | #8 |
After reading a bit more about this, it turns out that the circumference does indeed contract and the radius remains constant. This can happen because of the fact that the measurement of the radius requires the addition of distances made over a continuum of different frames of reference while the radius is measured in one, comoving frame.
http://www.physicsforums.com/showthread.php?t=84734 This implies that the reasoning of my earlier post is incorrect. Here is the justification given by Lightman et al. Suppose we are in the frame where the disc rotates with angular speed [latex]\omega[/latex]. The total energy of the disc is [latex]N m \gamma[/latex]. Thus [latex]T^{00} 2\pi r dr dz = N m \gamma \implies T^{00} = \frac{Nm\gamma\delta(r-a)\delta(z)}{2\pi a}[/latex]. The confusing thing is why they use [latex]2\pi r[/latex] even though the disc is rotating so its circumference is contracted to [latex]2\pi r/\gamma[/latex]. It looks like the authors have made a mistake here. A further piece of evidence suggesting that the authors are in error is their bizarre expression for [latex]\rho_0[/latex] which they conclude depends on the inverse of gamma. If one assumes that the circumference contracts, one will find that [latex]\rho_0[/latex] is indeed independent of gamma as it should be. Interesting. |
| Jul17-08, 11:07 AM | #9 |
If the radius decreases and the circumfernece does not, this implies that the space-time is curved. Cosidering we have accelerating frames this is not a surprise.
The best paper I've seen on rotating frames is here ( reprinted this year) arXiv:gr-qc/9805089 but they don't look at the SET so maybe not relevant. |
| Jul17-08, 07:07 PM | #10 |
The energy density of the rotating hoop has been given in strange units that look [to me] like: kg*differential_area/(contracted_circumference*dilated_second) (or, kg*m/s). I'm out of my league here, so don't assume "dilated_second" is where the extra gamma comes from. Regards, Bill |
| Jul17-08, 08:24 PM | #11 |
Hi Bill,
This topic was covered about a year ago by Pervect and others but I can't find the post. |
| Jul17-08, 08:40 PM | #12 |
Regards, Bill |
| Jul17-08, 09:58 PM | #14 |
Bill,
that's the one. I'm sorry the paper I cited isn't relevant, being more about the relativity of rotating frames. Worth finding that thread though, it's got some big guns. M |
| Jul18-08, 09:33 AM | #15 |
Getting back to the OT, the solution is now to clear to me.
Since the hoop is rotating at a radius [latex]a[/latex] from the origin in the lab frame, the circumference is dilated in the frame of the hoop to [latex]2\pi a \gamma[/latex], but the radius remains fixed at [latex]a[/latex]. Thus the rest-mass density must be [latex]\rho_0 = \frac{Nm \delta(r-a) \delta(z)}{2\pi a \gamma}[/latex]. At each point along the hoop, the the constituents of the hoop may be regarded as dust traveling with velocity tangential to the hoop. The energy density of the hoop is thus given by 00 component of [latex]\rho_0 u\otimes u[/latex], ie [latex]T^{00} = \gamma^2 \rho_0 = \frac{\gamma Nm \delta(r-a) \delta(z)}{2\pi a} [/latex] |
| Thread Closed |
Similar discussions for: Stress energy tensor of a rotating hoop
| stress energy tensor for rotating disc | Special & General Relativity | 1 | ||
| Stress-energy tensor of a wire under stress | Special & General Relativity | 178 | ||
| Stress-Energy Tensor | Special & General Relativity | 17 | ||
| Stress-Energy tensor of a rotating disk | Special & General Relativity | 2 | ||
| I can't see how stress-energy tensor meets the minumum tensor requirement | Special & General Relativity | 4 | ||
