Calculating River Flow Rate from Boat Trip Data
The problem involves calculating the flow rate of a river based on the time taken for a boat to travel downstream and upstream over a fixed distance. The subject area pertains to kinematics and relative motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss calculating the boat's speed in both directions and question the method of finding the river's flow rate. There is exploration of how the boat's speed combines with the river's speed to yield the observed speeds in each direction.
Some participants have provided guidance on forming equations based on the boat's speed and the river's speed. There is an ongoing exploration of the relationships between these speeds, and one participant appears to have reached a potential solution, though confirmation is sought.
Participants are working within the constraints of a homework assignment, which may limit the information they can use or the methods they can apply.
osker246
A boat takes 2.0 hr to travel 31 km down a river, then 6.0 hr to return. How fast is the river flowing?
r=d/t
first started out by finding the rate the boat traveled in each trip.
31/2=15.5 km/hr
31/6=5.2 km/hr
Now this is where I am not sure if I am solving this correctly. I then find the difference between the two rates and the time taken to travel both ways.
10.3 (difference of 15.5-5.2)/4(difference of 6-2)=2.6 km/hr
Is this the correct way of solving this problem? Thanks!
Hi osker246,
r=d/t
31/2=15.5 km/hr
31/6=5.2 km/hr
No, I don't think that's right. Notice is you keep units on your calculation you'll get km/hr^2.
So work with the total rate on each trip that you found. The boat has a speed, and the river has a speed. How do those combine to give 15.5 km/hr on the one trip, and how do they combine to give 5.2 km/hr going the other way?
alphysicist said:
Hi osker246,
hey alphycist,
Im not sure if I follow what your trying to say. Obviously when the boat travels 15.5 km/hr it is traveling with the current and when it travels 5.2 hm/hr its traveling against the current. I'm at a loss how you find the rate the current moves though.
osker246 said:
hey alphycist,
The boat has a speed [itex]v_b[/itex] (measured in still water), and the water has a speed [itex]v_w[/itex]. How do you combine those to get 15.5 km/h? How do you combine those to get 5.2 km/h? That will give you two equations and then you can solve for both of the unknown speeds. Does that make sense?
Ok I think I do understand. Tell me if this is correct.
Vb + Vw = 15.5
and
Vb-Vw = 5.2
Ok so I solved Vb + Vw = 15.5 for Vb. Giving me Vb=15.5 - Vw.
I then pluged in Vb=15.5 - Vw, into the equation Vb-Vw = 5.2 then solving for Vw.
So...
15.5-Vw-Vw=5.2
-2Vw=-10.3
Vw=5.15
Is this correct?
That sounds right to me.
Alright! The answer was correct! Thank you very much alphysicist. I appreciate it.
Sure, glad to help!
11K
  • · Replies 22 ·
