Purpose of Ferrite Bead in Ground isolation
The discussion centers on the purpose and characteristics of ferrite beads used for ground isolation, particularly in the context of separating digital and power grounds. Participants explore the implications of ferrite beads for noise filtering and their frequency response characteristics.
  • One participant suggests that ferrite beads help filter power noise and prevent digital line return path noise from affecting power levels, particularly in contrast to analog ground.
  • Another participant notes that filters work in both directions but are ineffective at 60Hz power line frequencies, emphasizing their role in blocking high-frequency noise.
  • There is a discussion about the selection of ferrite beads, with one participant indicating that different ferrites have different properties, implying that selection is important for specific applications.
  • Questions are raised about the frequency response of ferrites, specifically comparing 200E and 120E ferrites and their characteristics in isolating analog and digital grounds.
Participants express varying views on the effectiveness and selection of ferrite beads, indicating that multiple competing perspectives exist regarding their properties and applications. The discussion remains unresolved on certain technical aspects, particularly concerning frequency response and selection criteria.
Participants mention specific frequency characteristics of ferrites without providing detailed definitions or assumptions, leaving some aspects of the discussion open to interpretation.
Chandra214
Hi,
please let me know the purpose of having a ferrite bead isolation for ground (between digital and power)?
as far as i understand. the ferrites will be helpful in case of power noise filtering.
And noise from digital line return path wouldn,t affect the power levels as it might do for analog ground(return path).
will the noise from a push button switch within digital circuitry affect my power Ground?
will that have frequency? (even though noise)
does "selecting a ferrite bead" carry any meaning for this?
The filters work in both directions, but have no real effect at the 60hz power line frequencies.
Line filters keep high frequency noise (like RF transmitters) from getting into the equipment and causing unwanted operation.
They also keep high frequency noise from getting out of the equipment, causing it to fail to meet (in the US) FCC part 15 rules.
No idea of what you are asking on the "selecting" question.
Since different ferrites have different properties, I suppose you select the correct ferrite for the job in hand.
Does a Ferrite have particular frequency response? Say a 200E Ferrite and a 120E ferrite, do they have frequency characteristics?
i want to isolate my Analog ground with digital ground through a ferrite, so that i can avoid specific planes for it.
http://www.fair-rite.com/cgibin/catalog.pgm
11K
  • · Replies 35 ·
9K
10K
