Is Simultaneity Absolute in the Train-Platform Thought Experiment?
  • Context: Graduate
  • Thread starter Thread starter calculus_jy
    Simultaneity
The discussion revolves around the concept of simultaneity in the context of the train-platform thought experiment, exploring how different observers perceive the timing of events (lightning strikes) based on their reference frames. It examines the implications of special relativity on the perception of simultaneous events and the calculations involved in determining the timing of light reaching observers in different frames.
  • One participant describes the scenario where a platform observer sees two light pulses arriving simultaneously, while a train observer, moving towards one light source, will perceive the events as non-simultaneous.
  • Another participant agrees that the platform observer's conclusion about simultaneity does not hold for the train observer, emphasizing that 'seeing' refers to when light reaches the observers' eyes.
  • A participant questions what the train observer will conclude regarding the timing of the lightning strikes after accounting for the light travel time.
  • It is noted that if the light reaches the train observer at different times, he must conclude that the events occurred at different times in his frame, despite being equidistant from the flashes.
  • Some participants discuss the assumption that the train observer is at the midpoint between the two ends of the train, which is a condition of the thought experiment.
  • One participant asserts that simultaneity is only a convention and not an absolute truth.
Participants generally agree that the perception of simultaneity differs between observers in different frames, but there is no consensus on the implications or interpretations of these observations. The discussion remains unresolved regarding the exact conclusions the train observer can draw about the timing of the events.
The discussion relies on assumptions about the positions of the observers and the nature of light travel, which may not be universally accepted. The implications of simultaneity are contingent on the definitions and frames of reference used by the participants.
calculus_jy
recently i read about the embankement-train thought experiement, however i find it diffcult to understand
supposer the right end of the platform is A and left B, a train of same length as platform travels from B to A direction.
In the reference frame of the platfrom, a observer in the middle M sees two light arrive simultaneously from A and B, so he measeure his distance from A and B and conculde he is in the middle, therefore the lightning is simultaneous.
Also from his frame(platform), and the two light pulse travels at same speed toward observer 2 on the mid point of hte train M' as the trains front and back are aligned with the platform. Since he sees obervers 2 moving towards A, he will conclude that observer 2 will not see the events as simultaneous.
However the problem is, since the notion of simultaneous does no take into account the time taken to travel from the event to the observation point(ie that time lights' travel is subtracted from time seen).
in the statement Since he sees obervers 2 moving towards A, he will conclude that observer 2 will not see the events as simultaneous. the first oberver has not taken into account that oberver 2 has to subtract the time taken for light to travel to him(observer 2)
What actually does the observer 2 see on the train?
When light reach him from point A and B, the train is not aligned with the platform, so when he subtracts the time it taken light to travel from A to him and B to him, what does he observe, and what is the space time coordinate (x,y,z,t) for the two events?
This is accurate. It does not mean that that the observer cannot calculate the whole scenario and express it from different frames. 'Seeing' in this context just means that the light reaches the observers eyes. If the two light beams are seen by the platform observer to arrive at the same time, he will correctly conclude that they will arrive at different times for the observer on the train.
he indeed conclude they arrive diff time for observer, however
what does the observer on train see, and what time will he conclude for the lightning strikes at A and B when he subtractes the time taken to travel from the time the light reaches him respectively
If the light from each flash reaches the observer at the center of the train at different times, and yet he knows he's an equal distance from each flash, then if he assumes the light moved at the same speed in both directions, he must conclude the flashes happened at different times in his frame.
why is it that he is equal distance from flash?
That's just an assumption of the thought-experiment, that each flash strikes at the position of either end of the train car, and that the observer on the train car is right at the midpoint between both ends. In his frame the train is at rest, so both ends of the train car always stay at the same position in this frame.
Note that things are only simultaneous by convention not in an absolute sense!
  • · Replies 26 ·
  • · Replies 39 ·
  • · Replies 221 ·
18K
  • · Replies 20 ·
