Infinite Tensor: Does Coordinate System Matter?
  • Context: Graduate
  • Thread starter Thread starter snoopies622
    Tensor
The discussion revolves around the implications of coordinate transformations on tensor components, particularly in relation to singularities and infinities. Participants explore whether the presence of infinite components in one coordinate system necessitates their presence in all systems, and whether coordinate transformations can eliminate singularities in tensor fields.
  • Some participants propose that if a tensor has at least one component equal to infinity in one coordinate system, it must also be the case in all coordinate systems.
  • Others argue that the components of a tensor are defined as real numbers and cannot be infinite, suggesting a contradiction in the initial premise.
  • One participant questions whether a coordinate transformation can eliminate singularities in a tensor field, suggesting that this might imply the components at a singularity cannot be determined using standard transformation laws.
  • Another participant notes that while singularities at certain points can be transformed away (e.g., at the horizon of a Schwarzschild space-time), this does not apply to all singularities, such as at r=0.
  • There is a distinction made between coordinate singularities and physical singularities, with some participants asserting that physical singularities cannot be transformed away, while coordinate singularities can be addressed through appropriate transformations.
  • One participant mentions that the Riemann tensor behaves differently at the Schwarzschild radius compared to r=0, indicating that while the metric can be transformed, the Riemann tensor may not be recoverable in the same manner.
  • Another participant highlights that the behavior of the Riemann tensor is contingent on the metric and its derivatives, suggesting that coordinate choices can influence the representation of tensors.
  • Concerns are raised about the uniqueness of points in the manifold when using certain coordinate systems, particularly at problematic points like r=0.
  • It is noted that a coordinate singularity lies outside the domain of a coordinate chart, complicating the representation of tensors at those points.
Participants express multiple competing views regarding the relationship between tensor components and coordinate systems, particularly concerning singularities and infinities. The discussion remains unresolved with no consensus on the implications of these concepts.
Limitations include the dependence on definitions of singularities and the nature of tensor components, as well as unresolved mathematical steps regarding the transformation laws applicable to tensors in different coordinate systems.
snoopies622
If in a particular coordinate system every component of a tensor is zero, then they are also zero in any other coordinate system. Is there an analogous relationship with infinities? If a tensor has at least one component equal to infinity in one coordinate system, must this be the case in all coordinate systems?
By definition, the components of the coordinate representation of a tensor are real numbers, and therefore cannot be infinite.
Perhaps I should put it this way. Suppose I have a tensor field with singularities -- that is -- points at which at least one of the tensor components becomes undefined. Can a coordinate transformation of the field eliminate the singularities? My guess is "yes", but this would mean that one would not be able to find the components of the tensor field at a (former) singularity in the new coordinate system by using the tensor transformation law that is appropriate for the rest of the field, and yet they would still be the components of a tensor. Is this correct?
One can transform away the singularity at the horizon of a Schwarzschild space-time but not the one a r=0.
In the FLRW space-time it's possible to transform away the big bang singularity at t=0 ( I heard this from Prof. Steven Weinberg himself).
If the field doesn't exist at some point, then you can't change that fact by choosing a coordinate chart, and then looking at the coordinate representation of that field.
Coordinate changes don't change the field -- they only change the coordinate representation of the field.
Mentz114 said:
One can transform away the singularity at the horizon of a Schwarzschild space-time...
Does this include the curvature tensor singularities? It looks like six of it's 256 components become undefined there. If I understand what Hurkyl is saying, this tensor does not exist at [tex]r=r_s[/tex] in any coordinate system.
No. You have to distinguish between two singularities: coordinate singularities and physical singularities. One can do that by computing scalar curvature quantities like [tex]R^{\mu\nu\rho\sigma}R_{\mu\nu\rho\sigma}[/tex] for a particular solution of Einstein's equations ( I believe it's called the Kretsch scalar ). If this quantity blows up, it will blow up in every coordinate system. For the Schwarzschild radius this quantity is perfectly finite, so this indicates that the Schwarzschild radius exhibits a coordinate singularity, and that it can be removed by maximal analytic extension.
Compare this with someone who flies into a black hole. An observer from the outside observes that this person will stand still at the Schwarzschild radius and never enters the black hole; the coordinate time of this process is infinite. The person itself however just goes by this radius; the eigentime to pass the Schwarzschild radius is finite.
We say that we can extend geodesics from outside the Schwarzschild radius to the interior of the black hole. However, this is not possible for the r=0 singularity; here the geodesics terminate.
So at the Schwarzschild radius, the metric tensor can be recovered with a coordinate transformation, but the Riemann tensor cannot be?
At the Schwarzschild radius the metric appears to be singular in spherical coordinates, but you can transform this away with a proper coordinate transformation. Everything behaves nicely there, and because the Riemann tensor is a function of the metric and its first two derivatives, also the Riemann tensor will behave nicely. The curvature is not "infinite" at the Schwarzschild radius, so there is no reason for the Riemann curvature tensor to behave badly there.
A frequently maded comparison is the r=0 singularity if you use polar coordinates in flat 2dimensional space. The Jacobian dissapears at r=0, but ofcourse this is just our choice of coordinates ( or, our choice of the origin ). If we would calculate the Riemann tensor in polar coordinates in 2 dimensions it would be zero because the connection terms are zero.
That r=0 is a problematic point can be seen by the fact that for r=0 but an arbitrary angle we remain at the same point; [tex](r,<br /> \phi) = (0,\phi)[/tex] for arbitrary [tex]\phi[/tex] is one single point on the manifold. That's no good, because we would like that every different coordinate indicates one unique point. Often we need more than one chart to cover a manifold.
I should explicitly point out that a coordinate singularity lies outside of the domain of a coordinate chart. Since the coordinates at such a point are not well-defined, all bets are off when you try to represent a tensor relative to those coordinates.
  • · Replies 40 ·
  • · Replies 22 ·
  • · Replies 33 ·
