Finding the charge of a capacitor
  • Thread starter Thread starter Indeed
    Capacitor Charge
The discussion focuses on calculating the charge on two capacitors, C1 (4 µF) and C2 (2 µF), which are initially charged in series across a 100 V battery. After disconnecting them from the battery, they are reconnected with positive plates to positive plates and negative plates to negative plates. The correct approach involves recognizing that the total charge remains constant when the capacitors are connected in this manner, and the charge on each capacitor can be calculated using the formula Q = V x C, where the voltage across the capacitors changes due to their new configuration.
  • Understanding of capacitor charge calculations
  • Familiarity with series and parallel capacitor configurations
  • Knowledge of basic electrical principles, including voltage and capacitance
  • Ability to apply the formula Q = V x C in practical scenarios
  • Study the principles of capacitor combinations in series and parallel
  • Learn about charge conservation in isolated capacitor systems
  • Explore practical applications of capacitors in electronic circuits
  • Review the impact of voltage changes on capacitor charge distribution
Students studying electrical engineering, physics enthusiasts, and anyone looking to deepen their understanding of capacitor behavior in circuits.
Indeed
Problem 62. Capacitors C1 (4 uF) and C2 (2 uF) are charged as a series combination across a 100 V battery. The two capacitors are disconnected from the battery and from each other. They are then connected positive plate to positive plate, and negative plate to negative plate. Calculate the resulting charge on each capacitor.
(Charge) = (voltage) or (potential difference) x (capacitance)
(Q)=(V)(C)
I added both capacitors to get a net capacitance, C12 (1.33 uF). Then I used 100V and 1.33 uF to get the charge, Q12 (133). I though that series capacitors had the same charge, but 133 is not the answer.
I don't understand the bit about connecting positive plates to positive plates, what is that?
(Q)=(V)(C)
They are asking that if you disconnected both capacitors while still charged from the circuit and then connected them in parallel in isolation from the battery, how much charge would there then be on the new combination. (Ignore the practicality of ever actually doing it.)
  • · Replies 18 ·
  • · Replies 18 ·
