Calorimetry Problem - Find Specific Heat of Liquid
  • Thread starter Thread starter Jacob G
    Calorimetry
The discussion focuses on solving a calorimetry problem to find the specific heat of an unknown liquid using a 50g copper mass. The copper is heated in boiling water and then placed in 250g of the liquid at an initial temperature of 20°C, reaching a final temperature of 25°C. By applying the principle of conservation of energy, the heat lost by the copper is equal to the heat gained by the liquid, allowing for the calculation of the liquid's specific heat using the known specific heat of copper.
  • Understanding of calorimetry principles
  • Knowledge of specific heat capacity
  • Ability to perform heat energy calculations
  • Familiarity with the formula Q = mcΔT
  • Study the specific heat capacity of copper (approximately 0.385 J/g°C)
  • Learn about the conservation of energy in thermodynamics
  • Practice solving similar calorimetry problems
  • Explore the concept of heat transfer in closed systems
Students studying physics or chemistry, educators teaching calorimetry, and anyone interested in thermodynamic principles and heat transfer calculations.
Jacob G
If anyone could possibly help me and explain how to do this problem it would be much appreciated..
A 50g copper mass is heated by placing it in boiling water. It is then placed in a beaker containing 250g of an unknown liquid at 20C. The final temperature of the weight and liquid is found to be 25C. What is the specific heat of the liquid? (Assume no heat is lost to the surroundings.)
Thanks..
That looks like a homework problem to me! You know the initial temperature of the copper mass and you know its mass and can look up its specific heat. That allows you to calculate the amount of heat energy in the mass before it was put in the lquid. Knowing that its final temperature was 25 C, you can do the same thing to find the final amount of hear energy in the mass. The difference is the energy transferred to the liquid. Again, you know the initial and final temperatures of the liquid as well as its mass so you can write down the initial and final amounts of heat energy in the liquid. Set their difference equal to the heat energy transferred from the copper to the liquid and solve for the specific heat.
10K
11K
