| Thread Closed |
Time-Varying Magnetic Fields Q#2 |
Share Thread | Thread Tools |
| Jul20-08, 10:56 AM | #1 |
Hello, i just got done ranting on Q#1 (its in another post, and im still in a ranting mode) and was about to go to bed for the day, when i figured "well heck i have been working on these 2 questions for 9 hours and have made almost no progress, asking the people in my class for help is like throwing a brick into the ocean and waiting for it to float, and my 1st Question (that i posted here) already had someone actually try and help me (which is a lot more help than what i have received through the past 30 chapters so far....) " so..... i figure before i pass out for the day i will post this 2nd question, for 2 reasons... 1) there is a very high chance that by myself i will miss this question, even though each chapter has several questions and point wise it wont really hurt which leds to reason #2) after i do miss it, i will already be on the next deadline to complete the next chapter (we go through a chapter a day) and i will more than likely never figure out WHY i missed it (again refering to the brick story) i guess i can add a 3rd reason being that, well heck you guys are actually very helpfull
1. The problem statement, all variables and given/known data A long, straight wire carries a current I = I0 cos(220πt), where t is time in seconds. Two sides of a fixed rectangular loop are 8.5 cm long and are parallel to the wire; the other sides are 0.80 cm long. The nearest long side is 2.0 cm from the wire. What is I0 if the maximum emf induced in the loop is 1.3 µV? (Ignore the small variation of the magnetic field across the loop and calculate any B values at the location where the loop is nearest the wire.) 2. Relevant equations sry... 3. The attempt at a solution there is a similar question in one of my books but it is slightly different. in which case i attempted to use it to obtain the answer but it didnt work out (here is what i tried) R = .085 L = .008 x = .02 E = 1.3E-6 w = 220*pi E / (( u_o * R ) / (2*pi) * ( w * ln( (x+L) / x ) * cos(w) ) = I other than that, i am at a loss of thought |
| Jul20-08, 11:43 AM | #2 |
Mentor
First things first: What's the value of B within the loop? What's the formula for the field from a long straight wire carrying some current? Then apply Faraday's law. What's the flux through that loop? What's the rate of change of that flux? (Take the derivative.) Set the max value of that to the given value for max EMF. |
| Jul20-08, 07:51 PM | #3 |
here is the work
N = 1 Length = .085 Width = .008 Distance = .02 Emax = 1.3E-6 W = 220*pi (this is my symbol for Omega) A = Length * Width u_o = 4 * pi * 10^-7 Emax = N * A * B * W find 'B' B = Emax / ( N * A * W ) solve for 'B' and plug it into... B for a straight wire == B = u_o * I / (2 * pi * Distance ) find 'I' I = B * (2 * pi * Distance) / u_o solve for 'I' thank you again Doc Al, now i shall go back to that other question and try to solve it. |
| Jul21-08, 03:11 PM | #4 |
Mentor
Time-Varying Magnetic Fields Q#2Here's how I would do this one. First find B: [tex]B = \frac{\mu_0 I}{2 \pi d} = \frac{\mu_0 I_0 \cos\omega t}{2 \pi d}[/tex] The flux is just B*A, and the EMF is the rate of change of the flux (ignoring signs): [tex]E = d\phi/dt = \frac{\mu_0 I_0 A \omega \sin\omega t}{2 \pi d}[/tex] The max value is when sin = 1, thus: [tex]E_{max} = \frac{\mu_0 I_0 A \omega}{2 \pi d}[/tex] Just solve for [tex]I_0[/tex]. |
| Jul21-08, 06:15 PM | #5 |
i have several notebooks and as we run through the chapters i just write down all notes i can. in the one notebook for chapter 30 (this chapter) i have for 'E'
E = N * A * B * W * sin(Wt) Emax = N * A * B * W E = -dIB / dt E = -B*L*Velocity E = I * Resistance now like i said before im not too good with the concepts, and i havent had any math classes yet (which hurts me on intergrals and derivitives and the like...especially since im in a calc based class lol ) but i am good at puzzles. i solve the problems by identifing the "pieces" that i am given, and what other pieces i can obtain through them. then relating them all together and solving for the missing parts. which is prolly why everyone in the class takes ~4 hrs a chapter to answer all 40+ questions and i end up taking 15+ hrs...however... i get more of them correct =) i dont know (in your equation) what the 'd' represents, but i pluged in Emax = 1.36E-6 d = .02 ?? A = Area of the square Length * width W = 220*pi and the answer came out to be .2893726238 the correct answer (from the key) is 0.277 and using my method i received .2766061844 (we are allowed a 1% error ratio) your answer prolly is correct but i think i screwed up the calculations somewhere sorry |
| Jul21-08, 06:30 PM | #6 |
Mentor
| Thread Closed |
| Tags |
| current, electric field, induced emf, magnetic field, square wire |
| Thread Tools | |
Similar Threads for: Time-Varying Magnetic Fields Q#2
| Time-Varying Magnetic Fields | Introductory Physics Homework | 4 | ||
| Laser cooling, varying magnetic field. | Advanced Physics Homework | 2 | ||
| Time-Varying Magnetic Field | Advanced Physics Homework | 2 | ||
| Time varying forces | Quantum Physics | 4 | ||
| Magnetic fields inducing electric fields - turning on lightbulb with magnetic field | Introductory Physics Homework | 3 | ||
