The Mystery of Photons and Gravity
The discussion centers on the relationship between photons, gravity, and mass, exploring why massless photons are influenced by gravitational fields, particularly in the context of general relativity. Participants delve into various concepts of mass, including rest mass, inertial mass, and relativistic mass, while addressing the implications of spacetime curvature.
  • Some participants note that photons have no rest mass but possess energy, which is sometimes equated with mass.
  • It is proposed that in general relativity, objects follow geodesics in spacetime rather than being attracted by gravity, suggesting that mass is not a prerequisite for gravitational influence.
  • Questions arise regarding the definition of "true mass" for photons, with discussions on invariant mass, relativistic mass, and other types of mass.
  • Some participants argue that spacetime curvature is equivalent to mass and energy distribution, while others seek clarification on this relationship.
  • There is a debate about whether inertial mass and gravitational mass are equivalent, with differing opinions on the implications of rest mass being zero for photons.
  • Participants discuss the kinetic energy of mass in the context of relativistic and Newtonian definitions, leading to further clarification on energy concepts.
  • One participant introduces the idea that photons may have oscillation energy and translation energy, raising questions about the nature of photon energy.
Participants express multiple competing views on the definitions and implications of mass in relation to photons and gravity. The discussion remains unresolved, with no consensus reached on several key points, including the equivalence of inertial and gravitational mass.
Participants highlight the complexity of mass definitions and their implications in general relativity, indicating that assumptions about mass may vary based on context. There are unresolved mathematical steps and definitions that contribute to the ongoing debate.
pixel01
I've learned that photons have no mass, so why they are still influenced by black holes or other large celestial bodies?
Hi pixel01! :smile:
Two answers:
i] Photons have no rest-mass
but they do have energy, and energy is mass.
ii] In general relativity, objects are not attracted by gravitation, they merely follow geodesics ("straight lines") in space-time.
So they don't need mass to be influenced by large bodies (though the amount of mass does affect which geodesic they follow). :smile:
tiny-tim said:
Hi pixel01! :smile:
Two answers:
Thank you tiny-tim,
So what is the true mass of a photon? Say a photon beam at 400nm wavelength.
pixel01 said:
Thank you tiny-tim,
Which kind of mass do you mean by "true"?
Invariant (aka rest or proper)
Relativistic (aka inertial or transverse)
Longitudinal
Komar
ADM
Bondi
I would say that the "true" mass is the invariant mass which is 0 for a photon.
Longitudinal
Komar
ADM
Bondi
I mean the moving-induced mass. The rest mass of photon is 0 already.
That would be inertial mass.
[tex]\lambda=[/tex] wavelength
[tex]f=\frac{c}{\lambda}[/tex]
[tex]h=[/tex] Planck's constant
[tex]E=hf[/tex]
[tex]m=\frac{E}{c^2}[/tex]
Regards,
Bill
That would only be the case for imaginary test objects. General relativity has no background, objects that have mass or energy do not have worldines in spacetime they are the curvature of spacetime. In other words spacetime curvature is mass and energy and how they are distributed. By the way the curvature of spacetime can cause both attraction and repulsion.
This is of course correct, but (as you already know) if the mass of the object is much less than that of the star that deflects its path, a test particle's path is an excellent approximation of the actual path.
(For those who don't know this already, a "test particle" is a particle that can move around in spacetime without contributing to space-time curvature. It's just a theoretical idea that we can use to approximately calculate the paths of real particles).
Let's take a spherical, non rotating not charged, homogeneous star: there is curvature outside of it; does it mean the stress-energy tensor T is non zero there because of the gravitational energy only? Or the tensor T is zero there?
I think a statement like
"spacetime curvature is mass and energy and how they are distributed."
needs some more precise justification... especially when using is.
Otherwise, I fear misconceptions that might arise from it.
In my opinion, "is associated with" seems more appropriate.
Wouldn't it also be gravitational mass?
Only where the invariant/rest mass is zero. Otherwise, inertial mass is a component of gravitational/relativistic mass.
Regards,
Bill
Regards,
Bill
Are inertial mass and gravitational mass not equal?
If You look at formula m=E/c² You can see that the kinetic energy of this mass is: E_kin=mc²/2=E/2.
So long as one can distinguish between rest mass and inertial mass, I'm inclined to say no (clarif: they are not equal).
I'm afraid I cannot. The "m" you are using might well be either rest mass or relativistic mass depending upon the usage - and relativistic kinetic energy can be described by:
[tex]KE=mc^2-m_0 c^2[/tex]
where [itex]m[/itex] is relativistic mass, and [itex]m_0[/itex] is rest mass.
Relativistic mass is not generally inertial mass (i.e. v=0 with respect to your usage), and rest mass is not generally gravitational mass (i.e. a photon). However, I think it is true that relativistic mass is generally equivalent to gravitational mass.
Perhaps someone more adept than I could clarify/correct what I have said.
Regards,
Bill
Agreed.
Welcome to PF!
Hi cryptic! Welcome to PF! :smile:
cryptic said:
… If You look at formula m=E/c² You can see that the kinetic energy of this mass is: E_kin=mc²/2=E/2.
ah … you're using the Newtonian definition of KE, E = m0v2/2.
The Einsteinian definition of KE differs, at low speeds, by an additive constant, m0c2:
E = mc2 = m0c2/√(1 - v2/c2),
since that is approximately:
E = mc2 = m0c2(1 + v2/2c2) + …, = m0c2 + m0v2/2 + ….​
So the Newtonian m0v2/2 isn't half of the Einsteinian KE, it's the tiny (compared with m0c2) second-order adjustment. :smile:
I don't think there's anything "kinetic" about rest energy.
Regards,
Bill
Hi Bill! :smile:
I'm just using "KE" as the opposite of "PE". :wink:
:smile:
Hi,
but isn't it so that Photons have two parts of energy: oscillation energy and translation (kinetic ) energy? And oscillation ground state energy is quantum mechanically E=hf/2.
I think seriosus discussion is not possible because my posts disappeer after few minutes. :smile:
Regards
The bowliverse must be an interesting place... :smile:
Regards,
Bill
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 34 ·
  • · Replies 62 ·
10K
  • · Replies 19 ·
  • · Replies 169 ·
11K
