Conditional probability and sum of rvs question
The discussion revolves around a problem involving conditional probability and the sum of random variables, specifically focusing on the calculation of Pr(y < A | x + y > B) where X and Y are defined with specific distributions. Participants explore analytical approaches and the potential need for simulation.
  • One participant presents a problem involving a normally distributed random variable X and a random variable Y with a probability mass point at 0 and a uniform distribution on (0,t].
  • Another participant questions whether the problem can be solved analytically or if it requires simulation.
  • A suggestion is made to use the law of total probability to express the conditional probability in terms of an integral involving the distributions of X and Y.
  • A participant describes their approach to calculating the conditional probability, detailing steps involving the cumulative distribution function (CDF) of Y and the probability density function (PDF) of X.
  • Concerns are raised about the complexity of the resulting integral and whether it can be evaluated analytically or needs numerical methods.
Participants express differing views on the feasibility of obtaining an analytical solution, with some suggesting it may be too complex while others propose methods to approach the problem. No consensus is reached on the best method to solve the integral.
Participants note potential limitations in their approaches, including assumptions about the distributions and the complexity of the integral involved in the calculations.
MrFancy
I'm trying to solve a problem as part of my research and it's giving me fits. It seems like it should be simple, but I can't wrap my brain around how to do it. The problem is:
Suppose X~N(0,s), and Y is a random variable that has a probability mass point at 0 but is otherwise uniformally distributed on (0,t] so that:
f(y)=k, y=0
f(y)=(1-k)(1/t), 0 < y < t
f(y)=0 otherwise
What is
where A and B are arbitrary constants?
I think I've calculated the convolution of X and Y, but I'm not sure how to get the density from there (and I'm not sure I have the convolution right either). Thanks for any help you can provide.
Does this look like something that isn't going to have an analytical solution and would need to be simulated?
Try using the law of total probability to get
[tex]Pr(Y<a|X+Y>b)=\int_{-\infty}^{\infty} Pr(Y<a|Y>b-x) Pr(X=x) dx[/tex]
Sorry for the sloppy notation, but if you change the limits of the integral, I think you should be able to compute the answer.
OK, thanks a lot, I hadn't thought of using the law of total probability.
Here's what I did, simplifying a little so that Y has a mass point at 0 and is otherwise U[0,1] instead of U[0,t]:
For the Pr(Y<a|Y>b-x) part,
1. take the cdf of Y evaluated at a, which is a(1-k)+k
2. subtract the cdf of Y evaluated at b-x, which is (b-x)(1-k)+k
3. divide by (1- the cdf of Y evaluated at b-x), which is 1-((b-x)(1-k)+k)
The bounds of integration should be b-a to positive infinity, since this probability is 0 if x<(b-a). Then the Pr(X=x) part is just the pdf of a normal random variable. This gives me:
[tex]Pr(Y<a|X+Y>b)=\int_{b-a}^{\infty} (1-k)\frac{(a-b+x)}{1-(b-x)(1-k)-k}\frac{1}{\sigma\sqrt{2\pi}}exp(-\frac{e^2}{2\sigma^2}) dx[/tex]
Does that look right? If so, isn't that integral too messy to evaluate?
What you did looks correct except that it should be exp (x...) but i think that was a typo. I don't know if you can integrate that or not, certainly you can approximate it using numerical methods. If you want to solve the integral I suggest using a software or asking someone else as I suck at calculus and woke up quite early this morning. Good luck!
