Measure High Voltage using Coil Inductor
The discussion revolves around methods to indirectly measure high voltage across a wire connected to a spark gap. Participants explore various techniques involving coil inductors, oscilloscope measurements, and considerations of signal characteristics, while also addressing the challenges posed by the setup and environment.
  • One participant describes their method of measuring voltage across a coil inductor and a resistor to infer high voltage, questioning if this approach can yield accurate results based on component properties.
  • Another participant suggests using the turns ratio of a transformer setup to relate primary and secondary voltages, although this is later contested by the original poster who prefers to avoid transformer configurations due to concerns about current levels.
  • There is a discussion about the nature of the signal, with one participant noting it resembles a short pulse DC or a sawtooth signal, raising concerns about the availability of appropriate measurement probes.
  • Some participants propose measuring the breakdown voltage of the spark gap using the distance between electrodes and the dielectric constant of air, while others caution against relying on estimates based on spark distances for formal documentation.
  • One participant expresses the need for a more direct measurement method for a journal paper, indicating that they are hesitant to derive equations for their specific setup.
Participants express differing views on the best method to measure high voltage, with some advocating for indirect methods involving inductors and others suggesting direct measurements based on physical properties of the spark gap. The discussion remains unresolved regarding the most effective approach.
Participants mention limitations related to the availability of measurement tools and the specific environmental conditions affecting their experiments, such as living on a small island. There is also uncertainty regarding the applicability of certain theoretical models to the practical scenario described.
Emreth
Hi everybody,
I need to indirectly measure the high voltage across a wire, which is one of the leads to a spark gap. I ran the wire through a coil inductor(air core) and measured the voltage across the coil leads with an oscilloscope when i get the spark. I also connected a resistor in series with the coil wires and measured the voltage across the resistor with the oscilloscope to get the current (all as a function of time). Can I calculate the voltage and current across the high voltage wire using the dimensions and electrical properties of the components?(inductance,etc). thanks
Not sure if this helps but you will have a primary coil and a secondary coil the ratio of the voltages is the same as the ratio of turn in each coil. V1/V2 = N1/N2. So if you know the number of turns in each coil you can calculate the voltage. I am pretty sure that the current will be in the same ratio but inverse i.e. V1/V2 = I2/I1.
Hi
I don't want to do it through a transformer setup. I'm afraid the current might be too high in the secondary coil.Besides i need to find the efficiency and stuff.Just trying to keep it simple.
Emreth said:
Hi everybody,
What is the bandwidth of the HV signal? If it is fairly low frequency or DC, you can use a low-frequency HV probe with your oscilloscope:
http://us.fluke.com/usen/products/A...ukeUnitedStates&Category=VPROBE(FlukeProducts)
You can even make one yourself (be careful!):
http://www.repairfaq.org/sam/hvprobe.htm
Hey
I thought about that, yeah its just a single pulse dc.But its a very short pulse, like 100 microseconds or something.Its more like a sawtooth signal so maybe i should consider it ac.The problem is I live on a small island..seriously..so i can't get a probe.Maybe i should make one, tho I'm trying to make this whole thing simple and basic as possible.
Emreth said:
Hi everybody,
Emreth said:
Hey
Are you trying to measure at what voltage the spark gap breaks down for different dielectrics or something of that sort? If not, then you can probably just measure the distance between the spark gap electrodes and using the dielectric constant for air, just arrive at the voltage applied. This should give you a rough figure of the voltage. (Note: since you live on an island, do not use the dielectric constant for dry air.)
I think you meant the breakdown voltage, as described by the Paschen curve. Here's a reference to that info for the OP:
http://en.wikipedia.org/wiki/Paschen's_Law
yup, that's what I meant.
thanks guys but this is for a journal paper.i'm sure referees will grill me for estimates based on the spark distances.i need something more direct than that. i didnt want to derive the equations for the setup i specified but i guess i have to do that. I thought it would be a common example on textbooks and stuff but i couldn't find it online really.
  • · Replies 34 ·
  • · Replies 78 ·
  • · Replies 19 ·
  • · Replies 27 ·
