How do I attach a heavy metal rod onto the ceiling?
  • Context: High School
  • Thread starter Thread starter BlueScorpion
    Metal Rod
The discussion focuses on methods for attaching a heavy metal rod to a ceiling, considering various factors such as ceiling material, rod specifications, and the intended use of the rod in a physics experiment.
  • Exploratory, Technical explanation, Debate/contested, Experimental/applied
  • One participant notes that the ease of attachment depends on the ceiling material, suggesting that wood ceilings are easier to work with than concrete, but concrete may offer greater pull-out strength.
  • Another participant requests additional information about the ceiling type, rod material and dimensions, orientation, loading data, and positional requirements to provide a more tailored response.
  • A suggestion is made to consider building a support frame that could be adjusted for better placement and control of stress loads on the rod, which has been effective in past experiments.
  • It is mentioned that while a support frame could be beneficial, it may also interfere with the experiment, though this can often be managed in the design phase.
  • Participants recommend using drop-in multiset anchors for concrete ceilings and Unistrut for flexibility in positioning and frame construction.
Participants express differing views on the best approach to attach the rod, with some favoring direct attachment methods while others advocate for a support frame. There is no consensus on a single solution, as the discussion remains open to various methods and considerations.
Participants highlight the need for specific information regarding materials and intended use, indicating that the discussion is contingent on these factors. The effectiveness of different attachment methods may vary based on the unique circumstances of the experiment.
This discussion may be useful for individuals involved in experimental physics, engineering projects, or anyone needing to securely attach heavy objects to ceilings in various material contexts.
BlueScorpion
I'm setting up a physics experiment but I have one problem.
Depends on things you've not specified. For instance, this is real easy to do with a wood ceiling but a little harder for concrete. But the pull-out strength in concrete would be greater than in wood.Give me the following info :
1. What ceiling is made of,
2. Material and dimensions of metal rod,
3. Orientation (hangs vertically from ceiling ?),
4. Other loading data (is something heavy attached to the rod, are forces applied to it...what is the purpose of the rod ?)
5. Does the position need to be exactly at a specific point? Would it be useful to have adjustability built into the position ?
The more info you can give, the better.
Not an answer to your question but rather a suggestion: you might be better off building a support frame that is almost as high as your ceiling and that you can move around. This allows you to better place and control the stress loads of the attached metal rod.
Worked great for me on one of my experiments!
True, unless the frame gets in the way of the experiment. But that can usually be managed in the design of the frame.
Check out drop-in multiset anchors for concrete. Also look at Unistrut(R) if you want positional flexibility. Unistrut is also good for buildling frames.
  • · Replies 16 ·
  • · Replies 66 ·
  • · Replies 36 ·
9K
