Weight = Pressure * Total Area
The discussion revolves around estimating the mass of a car based on the gauge pressure in its tires and the area of the tire footprints. The subject area includes concepts of pressure, force, and area in the context of physics and mechanics.
  • Participants explore the relationship between pressure, area, and mass, questioning whether to include atmospheric pressure in their calculations. There is discussion on whether to treat the tires collectively or individually based on their uniform pressure.
Some participants have provided guidance on the correct application of pressure in the calculations, emphasizing that pressure should only be used once. There is an ongoing exploration of the implications of uniform pressure across the tires and how to approach the problem correctly.
Participants are considering the implications of gauge pressure versus absolute pressure and the necessity of converting units from cm² to m². There is also a note on the potential variability of tire pressures in different scenarios.
#H34N1
The gauge pressure in each of the four tires of an automobile is 240 kPa. If each tire has a "footprint" of 220 cm2, estimate the mass of the car.
@Mods: please move if this is too easy for this forum.
Welcome to PF!
Hi #H34N1! Welcome to PF! :smile:
Show us how far you've got, and where you're stuck, and then we'll know how to help you! (same for your other thread, of course) :smile:
[hide=My work]Pressure = F/A.
There are four tires and four footprints so the total pressure of all four tires is 240*4+101.3 = 1061.3.
I am not sure if I need to add the atmospheric pressure to the gauge pressure. There could be reasons for both. Adding atmospheric pressure is correct because it is the pressure against which the tire is inflated. On the other hand, the atmospheric pressure also adds to the mass of the car so I am not sure how to proceed here.
The total area is 220*4 = 880cm^2. We now have to convert to m^2 because the initial footprint is given in terms of cm^2 and the pressure is given in kPa. $=0.088$.F = mg, so we have
1061.3 = mg/0.088
Solving for m, we have m=9.53004082 kg, which does not seem right.
You can not add pressure in this case.
Hi H34N1! :smile:
Yes, pixel01 is right:
pressure = total mass / total area.
You must only use the pressure once! :smile:
hmm … on second thoughts, although that statement is correct, it only works because all the tyres have the same pressure (which they need not), and so in the general case you should consider each tyre separately.
The amount of weight supported by each tyre (equal to the reaction force on that tyre from the ground) divided by the contact area for that tyre equals the pressure for that tyre:
W1 = P1A1 etc
In this case, the Ps are all the same.
So total weight = W1 + W2 + W3 + W4 = P(A1 + A2 + A3 + A4) :smile:
19K
9K
10K
