Calculate Volume of Parabolic Region with Equilateral Triangles
  • Thread starter Thread starter ewad
    Volume
The volume of a parabolic region defined by the inequality {(x,y)|x^2 PREREQUISITES
  • Understanding of parabolic equations and their graphical representations
  • Knowledge of equilateral triangle properties and area calculations
  • Familiarity with volume integration techniques in calculus
  • Ability to visualize cross-sections in three-dimensional space
  • Study the derivation of the volume of solids with variable cross-sections
  • Learn about integration techniques for calculating volumes, specifically using the disk and washer methods
  • Explore the properties of equilateral triangles and their applications in geometry
  • Practice similar calculus problems involving parabolic regions and cross-sectional areas
Students in calculus courses, educators teaching geometry and volume calculations, and anyone interested in applying mathematical concepts to solve real-world problems involving parabolic shapes.
ewad
The base of S is an parabolic region {(x,y)|x^2<y<1}. Cross-sections perpendicular to the y-axis are equilateral trinagles
pls help
no clue
Draw it out. The cross-section in the yz-plane is half of a parabola: the heights of the triangles.The easiest way to approach the volume of this shape is to use your knowledge of the area of each triangle.
This is a standard homework problem so I am moving this to the homework section.
It will help you to know that if an equilateral triangle has side length s, then it has altitude [itex]\sqrt{3}s[/itex] and so area [itex](\sqrt{3}/2)s^2[/itex].
19K
