| Thread Closed |
Pole and Barn paradox - close the doors for good! |
Share Thread |
| Jul30-08, 08:25 AM | #1 |
As I was reading Fabric of the Cosmos, I got stumped at the relativity of simultaneity section. This led me to Google for some additional explanation. I stumbled upon http://www.phys.unsw.edu.au/einstein...le_paradox.htm which made me think of this question regarding the pole and barn paradox.
I searched around the forum and I didn’t find an answer to my specific question – here goes: If the person running with the pole appears to the spectator (at a distance) to be inside the barn completely with the doors shut, how can the person running with the pole think that the pole is hanging out of the barn? I understand how only if the doors are simultaneously shut (according to the spectator) and immediately opened b/c the person running with the pole would not agree with the simultaneous shutting and opening. So to the runner, the first door shuts while the back door is still open allowing the pole to hang out, and then the front door opens while the front of the pole moves out of the barn and then back door shuts. But if both doors are shut, and shut for good, doesn’t it come down to whether the pole is in the barn, or whether the back door came crashing down on the end of the pole? One of my problems is right here: if the doors are closed forever, is the pole in the barn or not? Shouldn’t this be the same for both observers? The pole would either be crushed by the door or not. If the simultaneity of the doors closing for good is still relative, couldn’t you time the closing so it appears simultaneous to the runner (i.e. have the back door close a bit earlier than the front door)? In this case it wouldn’t be simultaneous to the spectator. But we can still ask if the pole is in the barn or did it get crushed by a door? I feel like to the runner, the pole is at a static length so it can’t ever be in the barn because it’s too big. This leads me to ask is this just an illusion based on perspectives of when doors are opening and closing and how the pole appears to the spectator (based on length contraction) to pass through the barn. I must be missing something here. John |
| Jul30-08, 08:49 AM | #2 |
May I suggets my tutorial on the subject at http://mysite.verizon.net/mikelizzi/...PoleInBarn.htm If you have a PC you can actually run the 3d graphics simulation. |
| Jul30-08, 10:14 AM | #3 |
Recognitions:
| Jul30-08, 12:53 PM | #4 |
Pole and Barn paradox - close the doors for good!I believe my question wasn't so clear. (but no need for mathematics - i'm only a microbiologist so extra math will make my head spin even harder!) I think this website answers my question http://math.ucr.edu/home/baez/physic...barn_pole.html The site states: What if the doors are left shut? If the doors are kept shut the rod will obviously smash into the barn door at one end. If the door withstands this the leading end of the rod will come to rest in the frame of reference of the stationary observer. There can be no such thing as a rigid rod in relativity so the trailing end will not stop immediately and the rod will be compressed beyond the amount it was Lorentz contracted. If it does not explode under the strain and it is sufficiently elastic it will come to rest and start to spring back to its natural shape but since it is too big for the barn the other end is now going to crash into the back door and the rod will be trapped in a compressed state inside the barn. My interpretation of this is that the pole actually fits in that barn. The spectator sees it in the barn and by shutting the doors for good, you can squeeze the compressed pole in the barn (probably destroyed by strain) for the runner to see too. MikeLizze- I believe I have a java issue here at work, so I will try later. Thanks! Thanks for your help. |
| Jul30-08, 02:53 PM | #5 |
Recognitions:
| Thread Closed |
Similar discussions for: Pole and Barn paradox - close the doors for good!
| Wire does a loop of wire create a norh pole and a south pole | General Physics | 2 | ||
| Wooden Screen Doors vs. Aluminum Doors | General Discussion | 6 | ||
| The Broad Side of the Barn | Calculus & Beyond Homework | 2 | ||
| Automatic doors | Introductory Physics Homework | 1 | ||
| Doors Closing? | General Discussion | 4 | ||
