Ionic concentration / number of ions
The discussion focuses on calculating the number of ions in a given volume based on concentration, specifically using the mole concept. A mole is defined as 6.022 x 1023 units, which can be molecules or atoms. For example, a concentration of 15 mM (millimoles) translates to a specific number of molecules using the formula: (15/1000) * 6.022 x 1023. Additionally, it is clarified that 1 liter of water contains approximately 55.55 moles, leading to about 3.34 x 1025 water molecules.
  • Understanding of the mole concept in chemistry
  • Basic knowledge of concentration units (mM, mol/L)
  • Familiarity with Avogadro's number (6.022 x 1023)
  • Ability to perform unit conversions and calculations
  • Learn how to calculate molarity and molality in different solutions
  • Explore the concept of molar volume and its applications
  • Research the implications of ion concentration in biological systems
  • Study the relationship between concentration and reaction rates in chemistry
Chemistry students, laboratory technicians, and researchers involved in chemical and biological experiments requiring precise calculations of ion concentrations and molecular quantities.
somasimple
Hi all,
We use often concentrations in chemical/biological experiments.
It is expressed usually in mili/µ mole/cm3 or mm3
Is there a way to know the number of ions contained in a volume?
Is there a way to know the number of ions (or density) on a surface knowing the concentration?
Sorry for these basic questions.
What is mole definition?
Mole: a chemical mass unit, defined to be 6.022 x 10E23 molecules, atoms, or some other unit.
Consider I'm stupid.
Not a mass unit, quantity unit. But you are right - 6.02x1023 of elements. Just an overgrown dozen it is.
Do you know how to calculate number of moles of substance given volume of sample and concentration?
I suppose.
If the concentration is 15 mMole then the number of molecules contained per unit of volume is:
(15/1000)*6.02x10E23
Wasn't that hard :wink:
Sure but I'm so lazy...
What is the volume unit on this page?
http://www.ncbi.nlm.nih.gov/books/bv.fcgi?rid=.0Doz_14FBoKlEE7VO_HAyJwxnZMXWZZQAN0H9
M usually stands for mol/liter.
Many salt are solvated in water.
How many water molecules are in a liter?
No matter, I found the response:
1 liter of water has mass about 1000 grams/liter.
Molecular mass of water=18
so No. of moles in 1liter = 1000/18= 55.55 moles
this multiplied by Avogadro's number: 6.022*1023
will give number of water molecules in 1 liter as:
55.55*6.022*1023 ~= 334.52*1023
  • · Replies 22 ·
14K
