Accelerometer xyz anlges to ra/dec
In summary, the speaker has mounted a tri-axis accelerometer on a telescope and is looking for a way to convert the angles from the accelerometer to either the ra/dec or alt/az coordinate systems. They are seeking help and recommendations for resources on how to do this conversion.
samkane
Hi !
I have mounted a tri-axis accelerometer on a telescope which gives me angles for x,y & z axis, is there a method to convert these angles to the ra/dec or alt/az coordinate systems.
Any help would be aprreciated
Astronomy news on Phys.org
Welcome to PF.
Depending on how you mounted it - you should get alt-az directly, converting to Ra/Dec isn't hard (remember that for a given Ra/Dec the alt-az constanlty changes as the Earth moves)
Try here http://seds.org/~spider/spider/ScholarX/coords.html or if you can find a copy there is the famous "astronomy with your pocket calculator"
1. What is an accelerometer and how does it measure angles?
An accelerometer is a device used to measure acceleration and changes in velocity. It works by using a small mass suspended by a spring, which moves in response to acceleration. The movement of the mass is then converted into an electrical signal that can be measured. In order to measure angles, the accelerometer must be equipped with additional sensors that can detect the orientation of the device in space. This allows it to measure the angle between the device and a specific reference point, such as the Earth's surface.
2. What is the difference between xyz angles and ra/dec angles?
XYZ angles refer to the orientation of an object in three-dimensional space, typically using the X, Y, and Z axes as reference points. This is commonly used in engineering and physics. RA/Dec angles, on the other hand, refer to the position of an object in the sky, using the celestial equatorial coordinate system. RA (right ascension) is the angle measured along the celestial equator, while Dec (declination) is the angle measured from the celestial equator towards the celestial pole.
3. How are xyz angles converted to ra/dec angles?
The conversion from xyz angles to ra/dec angles depends on the orientation of the device in relation to the Earth's surface. This can be determined using the device's accelerometer and additional sensors, such as a gyroscope and magnetometer. The data from these sensors is used to calculate the device's orientation and then convert the xyz angles to ra/dec angles using mathematical equations and algorithms.
4. What are some applications of using accelerometer xyz angles to measure ra/dec?
The use of accelerometers to measure xyz angles and convert them to ra/dec angles has many applications. One common application is in astronomy, where accelerometers are used in telescopes and other equipment to accurately track the position of celestial objects. They are also used in navigation systems, such as in aircraft and spacecraft, to determine their orientation and position relative to the Earth. In addition, accelerometers are used in virtual reality and gaming technology to track the movement of a user's head or body.
5. How accurate are accelerometer xyz angles when measuring ra/dec?
The accuracy of the measurements obtained from an accelerometer depends on various factors, such as the quality and calibration of the device, external factors that may affect its readings, and the algorithms used to convert the data. In general, accelerometers have a high degree of accuracy and can measure angles with precision. However, for more precise measurements, additional sensors and advanced algorithms may be necessary to account for any errors or disturbances.
  • Astronomy and Astrophysics
16K
  • Mechanical Engineering
