Entangling Photons: A Brief Overview of Quantum Interference
  • Context: Graduate
  • Thread starter Thread starter thenewmans
    Photons
The discussion focuses on the methods of entangling photons, particularly through the process of parametric down conversion (PDC). Participants explore the principles behind photon entanglement, the types of PDC, and the implications of experimental setups like beam splitters and Young's slits in relation to photon behavior.
  • One common technique for entangling photons is parametric down conversion (PDC), where a single photon is split into two "daughter" photons that are entangled.
  • Participants note that there are two types of PDC: Type I and Type II, both relying on a non-linear crystal to produce entangled photon pairs.
  • It is mentioned that the conservation properties of energy, momentum, and spin are maintained in the process of photon entanglement.
  • One participant questions whether beam splitters and Young's slits can produce photon pairs, expressing uncertainty about their effects on photon numbers.
  • Another participant clarifies that beam splitters do not change the number of photons; one photon input results in one photon output, and interference patterns depend on the detection process.
There is agreement on the use of parametric down conversion as a method for entangling photons, but uncertainty remains regarding the role of beam splitters and Young's slits in producing photon pairs, with differing interpretations of their effects on photon behavior.
Participants express varying levels of understanding regarding the technical aspects of photon entanglement and the implications of experimental setups, indicating a need for further clarification on these topics.
thenewmans
How do you entangle photons?
Since no one is answering this...
One of the common technique of getting entangled photos is by using something called a "parametric down conversion". This is where one photon comes in into a crystal and is split into two. The "daughter" photons together obey the conservation properties of the original photon. That property is what is being "entangled" between the two resulting photons.
I thought I had a webpage that gives a rather simple, non-technical explanation of this, but now I can't seem to find it. A google search will give you plenty of technical papers on this topic, though.
Zz.
As ZapperZ says, the primary technique is through PDC (parametric down conversion).
There are 2 types of PDC, Type I and Type II. They both rely on a similar underlying principle. A laser input beam of a known wavelength in sent into a non-linear crystal (basically like a small lens) tuned for the input wavelength. Most of the input photons pass through unchanged - and these are ignored. Perhaps one in a million, however, undergoes a metamorphosis. It emerges as 2 photons. Because of conservation of energy, momentum, spin, etc, they are each half the energy and twice the wavelength of the original. Total spin is conserved, so knowing the polarization of one tells you the polarization of the other. They are entangled because they exist as a superposition of states until they are observed. Because these entangled photon pairs emerge off-angle from the original input beam, they can be captured and pulled aside for testing - often using fiber optics and lensing mechanisms to manipulate.
Below is a technical link, unfortunately just about any description of the process gets complicated and confusing very quickly:
http://scotty.quantum.physik.uni-muenchen.de/publ/achtbild.pdf
Does that mean that beam splitters and Youngs Slits DO NOT produce photon pairs with laser light? I have always been unsure about this. Anyone know the correct answer?
That is correct. Those experiments do not change the number of photons. If you send one photon into a beam-splitter, you get one photon out. Until that photon interacts with a detector, it is indeterminate, which way the photon went. If the two paths are reunited before the photon is detected, you get interference. If the photon is detected first, you don't get interference.
  • · Replies 24 ·
  • · Replies 58 ·
