Before I attempt this next problem on sliding blocks
  • Thread starter Thread starter redshift
    Blocks Sliding
The problem involves two objects, A and B, placed on a horizontal, frictionless surface, with a force applied to object A. Participants are discussing the implications of the problem statement regarding the forces acting on both objects and their respective accelerations.
  • Participants are questioning the interpretation of the problem statement, particularly the meaning of "opposite surface" and whether the 8.0N force acts on both objects simultaneously. There is discussion about the implications of Newton's third law in this context.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the assumptions about the forces acting on the objects, but no consensus has been reached on the exact implications of the problem statement.
Participants note the lack of clarity in the problem's wording and the implications of the frictionless surface on the forces involved. There is an acknowledgment of the assumptions being made regarding the forces acting on both objects.
redshift
I'd like to make sure I understand it.
It reads...
"Two objects, A and B, are placed in contact with each other on a horizontal, frictionless surface. Object A weighs 1.5kg, and B weighs 2.5kg. If a force of 8.0N is exerted on the surface of object A in contact with B AND on the opposite surface, (1) determine the acceleration of A and B (2) determine the force pushing B."
Do you think this means 8.0N is applied to both objects A and B simultaneously?
(I assume "opposite surface" means the side of A opposite to that contacting B.
I feel for you; I think the textbook writer is much too vague:
1)
You write:
I also have that assumption..
2)
We now come to the heart of the matter:
Does there act a force on B equal to 8.0 N simultaneously with the force(s) acting on A?
This will be true if we ASSUME that the force on A on the contact side, is in fact, generated by B (nothing else makes much sense, I think).
Then, by Newton's 3.law, an equal, and opposite force acts upon B from A.
I believe this is what the problem writer is after..
Thanks again. Since the surface is frictionless this is what must be meant.
(1) its simply using F = ma, u are given F and m = the sum of the other 2
(2) i think for the second one you have to find the Force via F = ma again, however you have the acceleration and also the mass. not sure tho
  • · Replies 20 ·
  • · Replies 45 ·
