How can I put this summation into a closed form?
  • Context: Undergrad
  • Thread starter Thread starter beadmaster
    Closed Form
The discussion revolves around finding a closed form for a summation of natural numbers, specifically the sum of all summations from 1 to an upper limit "K". Participants explore the mathematical formulation and connections to known summation formulas.
  • One participant seeks a closed form for the summation of natural numbers from 1 to K, expressed as a series of nested summations.
  • Another participant provides the known formula for the sum of the first n natural numbers, \(\sum_{i=1}^n i = \frac{n(n+1)}{2}\), and applies it to derive the sum of sums.
  • The derivation involves combining known summation formulas, including the sum of squares, to arrive at a simplified expression.
  • Participants express surprise and appreciation for the elegance and simplicity of the final formula derived from the calculations.
  • One participant acknowledges familiarity with the final answer, suggesting it may have been encountered previously.
  • Another participant comments on the elegance of the proof and inquires about the contributor's expertise and the time taken to arrive at the solution.
Participants generally agree on the correctness of the derived formula, with expressions of appreciation for the mathematical elegance. However, the initial inquiry remains open-ended regarding the approach to finding the closed form.
The discussion does not resolve all assumptions or dependencies on definitions related to the summation process.
Readers interested in mathematical summation techniques, closed-form expressions, and elegant proofs in mathematics may find this discussion beneficial.
beadmaster
Hi,
I can't think / remeber how to write the following expresion in a closed form,
the function is a summation of natural numbers between 1 and an upper limit "K", written as
Sigma x with limits K and 1 effectivly, straightforward etc...
what i want is the summation of all the "summations" between K and 1 so sigma (1,K) + sigma (1,(K-1)) + sigma (1,(K-2)) etc.. until it reaches sigma (1,1) ie 1.
its easy to visulise, take K as 5, the expression would be
5+4+3+2+1
+4+3+2+1
+3+2+1
+2+1
+1
which gives 35, i am wanting the answer in terms of K (im presuming its possible) or at least can be written much neater than an expansion, cheers (I thought it could possibly be written as a general sigma summation but prehaps with tending limits, but if so how do you represent the tending being discrete and not continous)
cheers,
tom
It is fairly well known that
[tex]\sum_{i=1}^n i= \frac{n(n+1)}{2}[/tex]
so your "sum of sums" is
[tex]\sum_{k=1}^n\left(\sum_{i=1}^k i\right)= \sum_{k=1}^n \frac{k(k+1)}{2}[/tex]
It is also (reasonably) well known that
[tex]\sum_{k=1}^n k^2= \frac{n(n+1)(2n+1)}{6}[/tex]
putting those together,
[tex]\sum_{k=1}^n \frac{k(k+1)}{2}= \frac{1}{2}\sum_{k=1}^n k^2+ \frac{1}{2}\sum_{k=1}^n k[/tex]
[tex]= \frac{1}{2}\left(\frac{n(n+1)(2n+1)}{6}+ \frac{n(n+1)}{2}\right)= \frac{1}{4}n(n+1)\left(\frac{2n+1}{3}+ \frac{3}{3}\right)= \frac{n(n+1)(n+2)}{6}[/tex]
You will note that for your example, with n= 5, this gives
[tex]\frac{5(6)(7)}{6}= (5)(7)= 35[/tex]
thats great thanks, i knew the general summations but tbh i wouldn't have the wit to make some of those connections, not currently at least...:P
cheers
That turns out be remarkably simple! I hadn't expected it to.
Actually, I was surprised that the final formula was so simple!
i recognise the final answer from somewhere else, o well thanks again
can i just mention that that "proof" or process appears increadibly elegant, how long did it take for you to do, could i be so intrusive to ask about you level of expertise as i am taken back by again by the elegence of the solution
cheers
  • · Replies 37 ·
