Existence of Singer Cycle in GL(n,q)
  • Context: Graduate
  • Thread starter Thread starter the_fox
    Cycle Existence
The discussion revolves around the existence of Singer Cycles in the general linear group GL(n,q), where GL(n,q) consists of nxn matrices with entries from a finite field with q elements. Participants explore the properties, implications, and proofs related to the existence and characteristics of these cycles, including their minimal polynomials and the relationship to the structure of finite fields.
  • Some participants propose that a Singer Cycle is defined as an element of GL(n,q) of order (q^n)-1 and inquire about proving its existence for all n and q.
  • Hints are provided regarding the cyclic nature of the multiplicative group of a finite field and the embedding of GF(q^n)* into GL(n,q).
  • There is a discussion on the existence of an injective homomorphism that preserves order, with some participants affirming this approach.
  • One participant suggests that a transformation T defined on GF(q^n) corresponds to a matrix in GL(n,q) and must have order q^n-1, seeking confirmation of this assertion.
  • Another participant questions the degree of the minimal polynomial of a Singer Cycle, suggesting that it may not always be n and proposing a counterexample based on a specific inequality involving the Mobius function and the Euler totient function.
  • Subsequent replies clarify that the minimal polynomial's degree is indeed n, linking it to the structure of GF(q^n) and its relationship with GF(q).
  • There is a discussion about the number of Singer Cycles and their similarity to companion matrices, with some participants challenging the correctness of these claims.
  • One participant emphasizes the need to understand how GL(n,q) acts on GF(q^n)* to establish the correspondence of Singer Cycles to linear transformations.
Participants express differing views on the degree of the minimal polynomial of a Singer Cycle and the implications of the number of such cycles. While some points are affirmed, significant uncertainty and debate remain regarding the existence of counterexamples and the broader implications of the discussed properties.
Participants note that the discussion involves unresolved mathematical steps and assumptions, particularly regarding the minimal polynomial and the conditions under which certain properties hold.
the_fox
Assume GL(n,q) is the general linear group of nxn matrices with entries in the finite field with q elements. Define a Singer Cycle to be an element of GL(n,q) of order (q^n)-1. How can we show that such an element always exists? That is, for all n and q.
Thanx in advance.
Hint 1: The multiplicative group of a finite field is cyclic.
Hint 2: GF(q^n)* can be embedded into GL(n,q).
I am aware of the first hint. For the second, by an embedding you mean an injective homomorphism? I would think that if someone could find such a map, say f, then f(a) would be the element we are looking for, where a is a generator of GF(q^n)*. Of course it should be established that f is order preserving. Am I correct?
Yup.
Take T:GF(q^n)-->GF(q^n), with T=ax, GF(q^n)*=<a>. Then there exists a basis {e_1,...,e_n} of GF(q^n) over GF(q) such that Te_j=Σa_ije_i and T corresponds isomorphically to a matrix A=[a_ij] in GL(n,q) which must necessarily have order q^n-1. Does that sound correct?
Yes -- good work! (Just make sure you notice that T is invertible.)
Allright, I'd like to take it a step further:how about a singer cycle's minimal polynomial? It seems that its degree is always n, but I can't prove it. Any hints? Thank you for your help morphism.
Do you have any reason to believe that is always the case? I don't immediately see how this can be proved. I actually think it may be false. If you can find a natural number n and a prime p such that the following inequality holds
[tex]\sum_{d | n} \mu(d) p^{n/d} < \varphi(p^n - 1),[/tex]
where [itex]\mu[/itex] is the Mobius function and [itex]\varphi[/itex] is the Euler totient function, then I can explain how this can be used to produce a counterexample. I haven't given this much thought, so it's very probable that this inequality may never hold.
I'll try to think about this problem some more later.
Ignore my previous post -- the term minimal polynomial slightly threw me off.
What you want to do is show that every Single cycle A arises as above, i.e. as a generator of GF(q^n)*. Then, if m(t) is the minimal polynomial of A, we can see that GF(q)[t]/<m(t)> is GF(q^n). Hence deg(m(t)) = [GF(q^n) : GF(q)] = n.
[Incidentally I think this will prove that [itex]\varphi(p^n - 1) \leq \sum_{d | n} \mu(d) p^{n/d}[/itex] for all n and p.]
Some googling brought up http://www.hull.ac.uk/php/masrs/2003/clgln2e2.pdf. You might find it useful.
Yeah you are right! At some point I thought of that, but for some reason I rejected it.. I'll look more into this. Btw taking the rational canonical form, you get that every singer cycle is similar to a unique companion matrix, which implies that there are as many singer cycles as irreducible polynomials of degree n over GF(q). Right? Thanx for the paper.
That's not quite right.. Any ideas about how many singer cycles there are?
But, how do we know that every singer cycle in GL(n,q) corresponds to a linear transformation T=ax, where a is a primitive element?
Just look at how GL(n,q) acts on GF(q^n)*.
  • · Replies 17 ·
  • · Replies 24 ·
  • · Replies 36 ·
  • · Replies 25 ·
  • · Replies 26 ·
