Probability Density Function with an exponential random variable
The discussion focuses on computing the probability density function (PDF) of a random variable Y defined as Y = log X, where X is an exponential random variable with parameter λ = 1. The correct cumulative distribution function (CDF) is derived as F_Y(y) = 1 - e^{-e^y}, leading to the PDF p(x) = e^x e^{-e^x} after differentiation. A critical error identified in the initial approach was the improper handling of the parameter λ during integration, which necessitated a substitution to maintain accuracy in the limits of integration.
  • Understanding of exponential random variables and their properties
  • Knowledge of probability density functions and cumulative distribution functions
  • Familiarity with integration techniques in calculus
  • Ability to perform variable substitution in integrals
  • Study the properties of exponential random variables in detail
  • Learn about variable transformations in probability theory
  • Explore integration techniques, particularly substitution methods
  • Review the derivation of probability density functions from cumulative distribution functions
Students and professionals in statistics, data science, and mathematics who are interested in understanding probability distributions and their applications in real-world scenarios.
lizzyb
The question is: if X is an exponential random variable with parameter [tex]\lambda = 1[/tex], compute the probability density function of the random variable Y defined by [tex]Y = \log X[/tex].
I did [tex]F_Y(y) = P \{ Y \leq y \} = P \{\log X \leq y \} = P \{ X \leq e^y \} = \int_{0}^{e^y} \lambda e^{- \lambda x} dx = \int_{0}^{e^y} e^{- x} dx = -e^{-x} \Big |_0^{e^y} = -e^{-e^y} + 1 = 1 - e^{-e^y}[/tex]
so
[tex]\frac {d F_{|X|} (x) } {dx} = p(x) = e^x e^{-e^x}[/tex]
Unfortunately the answer isn't in the back of the book. Does that look okay?
I did [tex]F_Y(y) = P \{ Y \leq y \} = P \{\log X \leq y \} = P \{ X \leq e^y \}[/tex][tex]= \int_{0}^{e^y} \lambda e^{- \lambda x} dx = \int_{0}^{e^y} e^{- x} dx[/tex]
This step is wrong. Obviously you can't just drop the [itex]\lambda[/itex] like that. I suspect what you did was a substitution but you kept the same variable. If you let [itex]u= \lambda x[/itex], then du= \lambda dx so the integrand becomes e^u du. But you need to change the limits of integration also. When x= 0, u= 0 but when x= ey, u= \lambda e^y. The correct integral is now
[tex]\int_0^{\lambda e^y} e^{-u}du= -e^{-u}\right|_{0}^{\lambda e^y}[/tex]
[tex]= -e^{-x} \Big |_0^{e^y} = -e^{-e^y} + 1 = 1 - e^{-e^y}[/tex]
so
Since [tex]\lambda = 1[/tex] I just sort of dropped/substituted it. Thanks :-)
  • · Replies 19 ·
  • · Replies 18 ·
