Sum of Series with Telescoping Equation
  • Thread starter Thread starter BoundByAxioms
    Series Sum
The problem involves finding the sum of an infinite series defined by the expression \(\sum^{\infty}_{0}(e^{\frac{n+1}{n}}-e^{\frac{n+2}{n+1}})\), which is noted to relate to telescoping series.
  • Exploratory, Assumption checking
  • Participants discuss the nature of the series as telescoping and question the starting index for the summation. There are attempts to express the series in terms of its components and to clarify the cancellation of terms.
The discussion is ongoing, with some participants affirming the telescoping nature of the series and others pointing out potential oversights in the initial setup, such as the starting index. There is no explicit consensus yet on the correctness of the initial approach.
There is a mention of the need to clarify whether the series should start at \(n=0\) or \(n=1\), which may affect the interpretation of the sum.
BoundByAxioms
Find the sum of the series: [tex]\sum^{\infty}_{0}[/tex](e[tex]^{\frac{n+1}{n}}-e^{\frac{n+2}{n+1}}[/tex])
Telescoping series equation.
Starting with n=0, I get: (e[tex]^{2}[/tex]-e[tex]^{\frac{3}{2}}[/tex])+(e[tex]^{\frac{3}{2}}-e^{\frac{4}{3}})+(e^{\frac{n+1}{n}}-e^{\frac{n+2}{n+1}}[/tex])=e[tex]^{2}[/tex] as n approaches infinity. Is this correct?
(e^2-e^4/3)
(e^4/3 - e^5/4)
(e^5/4 - e^6/5)
+e^(n+1/n - e^(n+2)/(n+1))
e^2 - e^(n+2)/(n+1) <-- you forgot this.
And should it be starting with n =1?
Yes, that's a "telescoping" series- every term except the first cancels a later term. Well done.
Alright! Thanks!
  • · Replies 16 ·
