| Thread Closed |
Negative values in covariance matrix |
Share Thread | Thread Tools |
| Aug10-08, 02:36 PM | #1 |
Hello
I had measured luminescence decay profile. Then I want to fit a function which would approximate my experimental date. For that I make a simple program in LabWiev. The problem is that, that program give me out a negative values in covariance matrix. Why that? P.S. Sorry for my English |
| Aug10-08, 02:56 PM | #2 |
Negative covariance is OK. It means that higher-than-average results from one variable will happen at the same time as lower-than-average results from the other variable.
For example, the covariance between how cold it is out and much people get sunburned is probably negative. If you have more intuition for correlation, this may help: the covariance between 2 variables is just the correlation between the variables, scaled by the standard deviations. |
| Aug10-08, 03:48 PM | #3 |
Ok
But problem is that the negative values is in diagonal elements. Diagonals elements of covariance matrix is [tex]\sigma^2[/tex]. So I get that errors of functions coefficients [tex]\sigma[/tex] is imaginary. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Negative values in covariance matrix
| Function negative for all values of x | Precalculus Mathematics Homework | 2 | ||
| Complex Number Covariance Matrix | General Math | 0 | ||
| passive sign convention (negative watts, and negative current confusion) | Advanced Physics Homework | 7 | ||
| Why do F- and OH- have negative S values? | Chemistry | 3 | ||
| Binomial Theorem - small values of x and approximate values | Precalculus Mathematics Homework | 7 | ||
