Order parameter of charge density wave in one dimension
The order parameter of a charge density wave (CDW) in a one-dimensional electron gas is defined as O_{CDW}(x)=\sum_s\psi_{L,s}^{\dagger}(x)\psi_{R,s}(x), where \psi represents the Fermion annihilation field operator in the context of the Luttinger model. The periodicity of the CDW is linked to the Fourier transform of the electron density, specifically highlighting that the order parameter captures the essence of density modulation through cross terms that break translational invariance. The discussion reveals that the momentum transfer, q, is quantized to specific values such as 0, ±2k_F, ±4k_F, indicating that the allowed periodicity for CDW in one-dimensional fermions is restricted to these discrete values.
  • Understanding of charge density waves (CDW) in condensed matter physics
  • Familiarity with the Luttinger model and its implications for one-dimensional systems
  • Knowledge of Fermion annihilation field operators and their role in quantum mechanics
  • Basic concepts of Fourier transforms in the context of electron density
  • Study the Luttinger liquid theory in detail to grasp its implications for one-dimensional systems
  • Explore the mathematical formulation of charge density waves and their order parameters
  • Investigate the role of momentum transfer in one-dimensional fermionic systems
  • Learn about the implications of translational invariance breaking in condensed matter physics
Physicists, particularly those specializing in condensed matter physics, theoretical physicists studying one-dimensional systems, and researchers interested in charge density waves and their properties.
Yiping
In one dimensional electron gas in charge density wave phase, as I know , the density of electrons will be periodic. The order parameter of charge density wave is written as
[tex]O_{CDW}(x)=\sum_s\psi_{L,s}^{\dagger}(x)\psi_{R,s}(x)[/tex]
For Luttinger model, the \psi is the Fermion annihilation field operator.
I am not very familiar with Luttinger liquid, I try to understand why the order parameter of CDW would be written in this form. If I try to construct an order parameter for CDW by myself, I would guess the Fourier transform of electron density will be a feature for CDW, but I don't know the periodicity of the CDW. If the order parameter is correct, for CDW with any periodicity, I should find that <O_{CDW}>=1. I am not able to construct such order parameter by myself.
I can't understand why the order parameter will be the summation of
[tex]\psi_{L,s}^{\dagger}(x)\psi_{R,s}(x)[/tex]
, it seems odd for me. Creating a right-moving electron and destroy a left-moving electron?
It does indeed seem odd. Are you sure the hermitian conjugate isn't present?
Yes, I copy the definition from J.Voits onedimensional fermi liquid p.1008
I try to start from the density operator [tex]\rho(q)=\sum_k c_{k-q}^{\dagger}c_k[/tex].
Then, decompose the Fermion operator[tex]c_k=\Theta(k)c_{R,k}+\Theta(-k)c_{L,k}[/tex].
Insert the relation into the density operator and expand it, I get four different kind of terms, with the same chirality or different chirality. After the Fourier transform, I think it is less odd for me.
The term[tex]c_{R,k-q}^{\dagger}c_{L,k}[/tex]seems to be the term [tex]\psi_R(x)^{\dagger}\psi_L(x)[/tex], but it is only for [tex]q\sim-2k_F[/tex].
The CDW order parameter seems to include only this kind of term. I guess it is because the Hermitian conjugate only present the term with [tex]q\sim2k_F[/tex], which just shows the same periodicity of CDW in real space.
Except that, after I expand the density operator in this way, terms with the same chirality will be [tex]\rho_R(x)+\rho_L(x)[/tex] which will not give periodicity in real space, since the momentum is "almost" conserved. So the density modulation must comes from the cross term(momentum is not conserved<>translational invariance breaks.), which shows in the original question.
Then I am confused again, does that mean the momentum transfer, q, can only be [tex]0,\pm2k_F,\pm4k_F,...\pm2^nk_F[/tex] which means in one-dimensional fermion, the allowed periodicity for CDW is restrict to be some specific value?
  • · Replies 0 ·
