Conduction through a spherical shell.
The discussion focuses on solving the heat conduction problem through a spherical shell with a thickness of 5 cm and a radius of 0.5 m. The initial formula used is Q=KA(T2-T1)/L, where K represents thermal conductivity. The user is guided to derive the differential area element in polar coordinates, dA = rdθ * rsinθ dφ, and to express the heat transfer as dQ = rdθ * rsinθ dφ * K(T1-T2)/0.05. While a full integration is suggested, it is noted that an exact solution requires accounting for the varying area between the inner and outer surfaces of the shell.
  • Understanding of heat conduction principles
  • Familiarity with polar coordinates in calculus
  • Knowledge of thermal conductivity (K) and its application
  • Basic integration techniques
  • Study the derivation of heat conduction equations in spherical coordinates
  • Learn about the impact of varying surface areas on heat transfer
  • Explore numerical methods for solving differential equations in thermal analysis
  • Investigate advanced topics in heat transfer, such as transient conduction
Students and professionals in thermal engineering, physicists, and anyone involved in solving heat transfer problems in spherical geometries.
kristen32123
How do I solve for the temperature at a certain time for conduction through a spherical shell? I have a shell 5 cm thick with a radius of 0.5m. I am starting with Q=KA(T2-T1)/L and I am completely lost as to where to go with it.
Thanks!
Imagine the sphere has lines of latitude and longitude drawn on it. The (differential element of ) area of a rectangle defined by these lines is ( working in polar coords [itex]r, \theta, \phi[/itex])
[tex]dA = rd\theta*rsin\theta d\phi[/tex]
so, using your formula
[tex]dQ = rd\theta*rsin\theta d\phi*K(T_1-T_2)/0.05[/tex]
Now integrate out [itex]d\theta, d\phi[/itex] between 0 and 2*pi, and that gives the formula for the whole shell.
Of course you don't actually need to integrate - just think about it and the answer is obvious.
This solution is not exact because we're ignoring the difference in area btween the outer and inner surfaces ...
To solve exactly one needs a differential dL of thickness. Not a trivial problem.
  • · Replies 19 ·
