Measuring Formaldehyde Concentration: The Role of NaOH
  • Thread starter Thread starter biobird
    Measure
The discussion revolves around methods for measuring the concentration of formaldehyde in a diluted solution, specifically focusing on a wet chemistry approach that involves sodium hydroxide (NaOH) and other reagents. The context includes practical applications in a laboratory setting, with an emphasis on simplicity and reasonable accuracy.
  • Homework-related
  • Albert seeks a method to measure formaldehyde concentration in a diluted solution and expresses that high accuracy is not necessary.
  • Lisab provides a detailed wet chemistry method involving iodine, sodium thiosulfate, sulfuric acid, and starch as an indicator, along with a formula for calculating formaldehyde concentration.
  • Albert inquires about the importance of NaOH concentration in the proposed method.
  • Another participant asks about the instrumentation available, specifically mentioning Gas Chromatography.
  • Albert mentions having access to advanced instruments but prefers a simpler method with a specified accuracy of ±0.5 percent.
  • Lisab later clarifies that a 1.0 M concentration of NaOH is suitable for the procedure.
  • A participant questions the necessity of adding NaOH to the procedure, seeking clarification.
Participants have not reached a consensus on the necessity of NaOH in the procedure, and there are varying preferences for measurement methods, with some favoring simplicity while others consider more advanced instrumentation.
The discussion does not resolve the implications of NaOH concentration on the measurement process, nor does it clarify the role of NaOH in the reaction. There are also unresolved questions regarding the accuracy and reliability of the proposed method compared to more sophisticated techniques.
This discussion may be useful for biologists or researchers looking for practical methods to measure formaldehyde concentrations in laboratory settings, particularly those with limited access to advanced analytical instruments.
biobird
Hello all,
In order to re-use formaldehyde from a dilluted solution (in water) I need to know the concentration of formaldehyde in the dilluted solution.
Can anyone tell me how to measure this concentration? It does not have to be very accurate.
thanks in advance,
Albert
Chemistry news on Phys.org
Hi biobird -
I'm not sure what equipment you have available to you, but here's a wet chemistry method that uses commonly available chemicals. It's from a commonly used test method to measure HCHO from wood products.
You'll need the following solutions:
0.05 M iodine
0.1 M sodium thiosulfate
1.0 M sulfuric acid
starch solution ~1%
Mix 25ml iodine + 10ml NaOH + 20ml of the solution you're testing. Let it sit 15 minutes away from light. Add 15ml H2SO4 and titrate immediately with the Na2S2O3. When the solution starts to become pale yellow add a few drops of starch solution as an indicator.
Do the same titration procedure on 20ml water (blank).
Calculate the HCHO concentration:
c[HCHO] = (Vo – V) * 750 * c[Na2S2O3]
Where
Vo = volume of Na2S2O3 used in blank titration, in ml
V = volume of Na2S2O3 used titrating the solution you're testing, in ml
c[Na2S2O3] = concentration of sodium thiosulfate in M (0.1 in this case)
c[HCHO] = concentration of HCHO in mg/L
Hello Lisab,
Thank you very much for your description of this procedure.
I will try it soon.
Does the concentration of the NaOH matter?
greetings, Albert
Also what kind of instrumentations do you have e.g. Gas Chromatography ?
Well, I guess we have this kind of instruments at the lab, but I never worked with it. I was actually looking for a quick and simple method with an accuracy of -let's say- plus/minus 0.5 percent. After all, I'm just a simple biologist:confused:
biobird said:
Hello Lisab,
I will try it soon.
greetings, Albert
Ooops, left that out!
1.0 M NaOH will do.
hi. may i know why NaOH has to be added? - just asking!
thnks
  • · Replies 21 ·
  • · Replies 131 ·
11K
